Old 03-09-2014, 09:14 PM
Great job on the lights!
Old 03-12-2014, 06:00 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default switch and fuse holder
Got these in the mail today (tks Kevin) gonna get them cleaned up and mount next to the originals (probably wire it hot so I can use when off)
this weekends project ... It will look stockish ... even tho they are LED's ... dont stick out too much etc...
B.
Old 03-12-2014, 10:58 PM
nikster's Avatar
nikster nikster is offline
They could be an option for the tractors with no headlights,,,,
Aim some forward, too,,,,,, better than no lights!!
Yup!
NIK,
Old 03-13-2014, 08:04 AM
sawdustdad's Avatar
Those lights are a great idea, and the location works perfectly without interfering with any attachments. I ordered a couple sets myself. Thanks for sharing.
I see in the ebay description that they are "9 watts." I think they are probably 0.9 watts. A nine watt LED in a small package like that will overheat quickly.
For those not familiar with LED lighting, a good rule of thumb when replacing incandescent lamps with LEDs is that LEDs are approx. 8-10 times brighter per watt than incandescents. That is, a 10 watt LED would be as bright as a 80-100 watt incandescent. So these three 0.9 watt LEDs would be as bright as a single 35 watt headlamp (approximately). "warm white" LEDs are less efficient than the cool white variety, and create more heat in the process. (they actually use an LED to excite a phosphor that then emits the warm white light). I think these particular lights would fall in the cool white spectrum.
Old 03-13-2014, 12:26 PM
jcsmith jcsmith is offline
Great idea, and beautiful install. Now I want some. Thanks for the link and idea. Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 03-13-2014, 01:17 PM
scgtguy's Avatar
Smile i'll bore you with a couple more light pics
don't think you can beat these for the price ... very functional, the only lights illuminating my garage.
Old 03-13-2014, 02:20 PM
The lights are nice!
Old 03-16-2014, 11:27 AM
CNeubauer CNeubauer is offline
I think I'm going to order some and try to mount them under the foot rests pointing out to light up the ends of the deck.
Old 03-16-2014, 12:19 PM
Originally Posted by scgtguy View Post
you get two (2) per pkg ...
looking for a good spot in the rear of my car for the other !
B.
Wire 2 of them up and place on the back of your car where they would resemble reverse warning lights (backup lights). Then when some clown is so close he is almost in the trunk of your car, and won't back off, turn them on from the dashboard.....
Jokers ALWAYS back off if they think you hit reverse..
Only thing better than having a Cub Cadet is USING one
Old 03-16-2014, 12:59 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Now THAT is a good idea. When mowing at night that is a problem that I often encounter.
I lost track of what I own a long time ago!
