#21
![]() Quote:
![]() We need to see a pic of this area: It already looks welded to me. Photo-0032.jpg |
#22
Wish I could see the end where the rod comes out of the cylinder, they look like the cylinders on my Johnson FEL. I just replaced the seals on the bucket cylinders for the same reason about 8 months ago. Remove the push rod dust seal and there's a internal C ring just below it. Remove the C ring and pull the push rod out of the cylinder, the top support bushing will come out with the push rod so it will be easy to check for wear or damage. I took my push rod assembly (with dust seal) to my local Farm Supply parts counter and they matched up the O rings, Teflon O ring spacers and dust seal for my cylinder. I got enough part's to do all four cylinder's for about $25.00 since the lift cylinders were the same dia. It was allot easier than I thought it would be.....Good Luck
#23
You might try looking on SURPLUSCENTER.com, you can probably find a good replacement & a pretty good price too. Good luck!
#24
IF you replace the cylinder, replace both. Unless you can find a cylinder with the EXACT same bore and stroke, and mounting at the old one. If not, your loader won't work properly.
#25
These people helped me source some cylinders that are very similar. Just check your measurements and call them, they have more then listed on the site.
http://internationalhydraulicsus.com MIke |
#26
Why can't you just take a picture of the end of the cylinder where the rod comes out? We are all trying to help you but you have done your best to make it impossible.
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
#27
Indeed, you probably only need a piston seal.
#28
Sorry it took so long could not reply on my kindle for some odd reason. The cylinders are welded and the back two are way bigger then the front two. Back two have no leaks. I found out napa does hoses and the front 4 hoses seem wet. That's where I am going to start. About 20 bucks to replace all 4 but there only 8-10 inchs long.
108, lights, electric mower and sleeve hitch. ![]() |
#29
hey I got one of these.
so many tractors, so little money |
#30
