Old 04-18-2014, 05:08 PM
Tunames Tunames is offline
No valve equipment. Gonna need at least one new valve if not both exhaust valves. The manual says that if doing valve work on these engines the exhaust valve has been updated and both valve and seat need to be replaced.I'll have to take it somewhere. Do you think I should pull the jugs off and just take them in? That way I can check the pistons and rings.
Old 04-18-2014, 07:12 PM
It's up to you. As many problems as these engines have as they get older, it's a risk doing that. My drop the governor gear, may lose a rod....
You can go to the expense and trouble of pulling the jugs but I'm afraid something may happen down the road that will waste all the work. I'm not a big fan of doing a partial rebuild. To me, it's all or none. And, you may fix it and it run for 10 years.
I'll say this the same way I'd tell a customer. If it was mine.... I'd take the whole engine in and see if they could do a valve job. Slap new ones in (if they can't be ground, which it looks like the head on the one valve you posted is bent), grind the existing seat and go on. Or do a complete rebuild. Your choice. That is what I recommend. Just my
Old 08-17-2014, 02:29 PM
Jonathan next time I ask you a question, remind to take your advice...
Old 08-17-2014, 02:48 PM
This doesn't sound good, what's the rest of the story?
Old 08-17-2014, 04:56 PM
CubDieselFan's Avatar
Indeed, he had some bad luck.
Old 08-17-2014, 05:14 PM
Jonathan suggested just doing a valve job and leave it alone. But no I had to tear it apart! still haven't got it back together (no time) parts are ridiculously pricey. And of course while the engine is out might as well fix this, clean up that, etc. etc. No problems yet though. If work slows down a little I will get it done.
Old 08-18-2014, 12:34 AM
LOL! I'll ummmm try to remember that.
