Old 04-18-2014, 06:27 PM
steved steved is offline
Default 105 engine power take off
I need some more help with another problem on the 105. I'm trying to take off the drive pulley on the front of the engine. I've removed the two set screws that are accessed through the clearance holes on the stamped sheet metal piece. I've sprayed the set screw holes with PB blaster. Should the pulley come off now? My next thought is to rig a gear puller across the front of the frame and use that as the stationary point. I'm attaching two pictures. Thanks again for any help.
