Old 05-15-2014, 09:08 PM
FlyingB FlyingB is offline
Jonathan you beat me by like 30 seconds. You had more detail though.
Phil
A nice 1710 and QA42A snowblower.....and more to come .
Old 05-15-2014, 09:21 PM
I have the reflexes of a cat, and the speed of a mongoose!
Old 05-15-2014, 11:25 PM
weatherby's Avatar
weatherby weatherby is offline
J-Mec..n Flyingb ....Thanks, I now have a better understanding what was going on back in the early 80's with Cub, IH, and MTD !
Any opinion on the average hours you can get out of a 17hp Kohler ?
Old 05-16-2014, 12:54 AM
Seen them fail with as little as 400, and as high, or higher than 1500. Depends on if they are always on flat ground, and how well they get maintained.
Old 05-16-2014, 01:32 AM
weatherby's Avatar
So 1700 hours would be on the very high end for that motor ?
Old 05-16-2014, 08:00 AM
Yes, that is on the high end for it but with that style of hour meter there is no way of knowing how many times it has cycled around. The small needle IIRC is 600 hours and if the key was left on it runs until the battery is dead. That is a good looking 782 and it looks to be an IH one. If you look at the serial tag it will tell you if it was built by IH or CCC. If it starts out 2050594 then it was built by IH and the front ports were an option and it will have a cast iron rear. If it has a model and serial then it was built by CCC. If the model number is XXX-784-XXX then the front ports were standard.
Great find on both of those tractors!
Old 05-16-2014, 08:19 AM
If you are interested in the history of these tractors there are some good books about them, but here is a small summary of the Cub Cadet.
http://www.xtrememotorworks.com/Cub_cadet_History.htm
Phil
Old 05-16-2014, 09:38 AM
jimbob200521's Avatar
Dual hydraulics/front remotes were an option on an IH built 782.
I'll take my medicine when I'm wrong, just never knew it was an option on an IH built 782. You learn something new every day, and it usually seems to come from this forum for me
Yes sir it is on the high end, at least. Granted, there are some people out there who get a golden egg, take care of it, and it lasts them 2000+ hours. But from what I've seen/read, that is not average. Then there some engines, like the last motor in one of my 1811's, that didn't get taken care of by the PO and was on deaths doorstep when I replaced it with something like 857 hours. That, usually, is not average. If taken care of it's whole life, not run in any poor circumstances (WOT no load frequently, clean cooling fins, regular oil/filter changes, etc) then I don't see why 1600-2000 hours would be out of the question (it may not be running like new at 2000 hours, though ) Problem is, most aren't taken proper care of so YMMV.
Seems like most peoples point of view on the KT/Magnum series motors is run them till they stop just because they are so expensive, and difficult, to overhaul properly.
-Ryan
Old 05-16-2014, 09:36 PM
weatherby's Avatar
After sandblasting , starting to primer some parts.
Old 05-16-2014, 10:09 PM
Good job! Keep up the good work.
