Old 06-09-2022, 02:47 PM
Talking
Well, the drag strip just south of town seems to be going wild every weekend and that's a hell of a lot more expensive a hobby.....er tax write off for some, than these puny tractors.
Old 06-10-2022, 02:17 PM
Farmall450's Avatar
Hell, by the end of this year.
I wouldn't doubt it. A full fluid change, belts, filters, and a battery are about what a narrow frame is worth anymore...don't even think about tires or a seat.
We only have 4 left so don't miss out. 30.00 each at Cub Cadet...
The darkminion_17
Would have bought them outside feebay if I saw them listed here, figured from the name it was you.
I can get CC parts at cost + 5%, so probably similar, but didn't want to wait on the dealer nonsense
Old 06-11-2022, 12:56 PM
fortyeightjake's Avatar
fortyeightjake fortyeightjake is offline
They are Chinese, not a problem for the tractor that I'm putting these on since I don't run it much but it may matter to some.
Old 06-12-2022, 10:14 AM
Farmall450's Avatar
What is the OEM?
Old 06-12-2022, 12:09 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
The currently available MTD issue is made in Worcester, MA USA by Lutco. B1SB6534 64F64PP
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-12-2022, 01:50 PM
They have used those bearings since they started offering 1" spindles and Shep was a pup.
Nothing new here.
Old 06-12-2022, 02:48 PM
Farmall450's Avatar
Yup. I was asking what the OEM of the NAPA bearing was.
Old 06-12-2022, 04:17 PM
Probably "The Far East" like 99% of everything else these days.
Old 06-13-2022, 09:00 AM
See attached.
Old 07-11-2022, 12:10 PM
Update on the NAPA wheel bearings above. The packaging says "assembled in China" however when I actually pulled the bearing out, they are Lutco USA bearings. Not sure what that's about but I won't complain.
