Old 05-28-2014, 04:14 PM
Originally Posted by dvogtvpe View Post
I prefer to use bubble wrap. I like the sound it makes when you tighten the cover bolts up. it usually leaks but I still have fun every time I reseal one. and once in a while it works. so a good time is had by all
That's the best! LMAO. Wonder if you could use bubble wrap instead of plastigage when you check a rod for clearance? The more pop's the tighter it is?
OMG!! LMAO!
Old 05-28-2014, 06:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
gotta throw that stuff in their once in a while .
good one on the plastigage Sam.
Old 05-29-2014, 01:06 AM
LOL guys!
Old 06-25-2014, 01:59 AM
GERKS 149 GERKS 149 is offline
finally got a chance to work on the Cub again. All went well this time. Took the back cover off the rear end and drained all the old fluid out and cleaned up the sludge on the top part of the housing with brake clean and heavy scott towels. This is the first rear that I have had that sludge in. Changed out the hydro filter with a new Cub one that is white not yellow. All the ones I have had have been yellow. Guess they made a change recently.
When I installed the back cover I have always had problems with the gasket seeping fluid on many occasions. This time, I put a thin layer of black RTV on it and let it set up for a week before I filled the rear with Hytran. Hopefully no leaks!! This was the moment of truth when I fired it up to mow. All is good-no chattering. I assume the new Hytran was the trick. Thanks for all your guys input. What a huge help. Surely thought I was replacing the pump with another one!!
Old 06-25-2014, 07:30 AM
Great news!
Old 06-25-2014, 12:16 PM
Glad to hear it!
Old 06-29-2014, 07:32 PM
jcsmith jcsmith is offline
Speaking of sludge, when I went thru my trans axle the axle housings were full of crap also. Bearings were good ,so new seals, gaskets , and hy-tran was all it needed.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
