#21
Ok Jon, I put a gauge on the hydro tonight and the best I can get pressure wise is 100 psi. We have not dug into the valves but at this point would it make a difference if we did or not? Thanks for the help so far guys.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
#22
Yuk. 100 PSI is way off. Hey, do you think the rear has been changed? I only ask because of this thread. Might be worth the time to make sure it has both valves. Otherwise, pull the relief valves. Not the big ones mind you, the little ones. Check that thread out I linked to. I put pics up in it. I'm lazy and don't want to post them again.
#23
Jon as far as I can tell this rear has not been changed and it has both of the needed valves so if dad doesn't pull them tomorrow I will do it after work, thanks.
#24
If it's a splined pump from a super it will (should) have both valves, but who knows what the PO did.
![]() Could your charge pump cover be on 180* wrong? Here is how it should look. I'm not sure it could be put on wrong but maybe. DSCN0865.jpg Are you guys 100% sure all the power steering lines are on correct?
#26
Ok here goes nothing. Oak our pump is splined and does appear to be mounted the same way as the one in your pic. The stamped name is on top and possibly a part # can be seen on the bottom.
Jonathan I very carefully and with a little trepidation removed the top relief valve. I removed the hex headed top which has an O ring at the top of the threads under the hex head. This part has a hollow core and appears to be good without any scratches or undue worn spots. Next came about an inch long spring also appearing to be in good shape albeit a really stiff puppy. The last piece to come out is the cup which is squared on the top and a tubelike appearance with a cone shape on the bottom. it too seems to be in good shape. I did not see any shims as described in the description though. My thoughts are leaning toward the pump or the unlikely tube attached to the wrong place. I am going to try to get my camera working and take some pics but at the moment the camera had dead batteries.
#27
We first tested at what I would call a high idle and the guage needle did not move. We were testing using the forward, toward the front, hole that had a plug in it. I saw on another forum that Roland used the rear hole more toward the middle of the top. When we raised the engine speed to at or near full throttle we got the approx 100 psi reading but it seemed to bleed off some. I say approx because our guage reads to 4000 lbs and the diff between the 100 lb marks isn't very much. We did not try a load test but could do that tonight as it is still set up to test but with the top implement relief valve removed. The guy that made up the guage for Eric said he has tested thousands of hydros and always used the plugged hole to do it. I am also thinking it is in the pump but we are going to trace out the lines again tonight. Many thanks for your help. Would the pump from most other hydros fit this hydro. We looked at the hydro in our 149 and it appears to be identical.
#29
Paul, no, only a super pump will work. The output shaft is different on the SGT's. I don't think this will help but it only takes a minute. When I rebuilt my steering box I had no steering at all. I ran it for 5 minutes and had nothing thinking I put it together wrong. I loosened the hose going to the steering ram and moved the wheel back and forth a few times and it started working. Give that a try maybe you'll get lucky.
#30
Todd, I think Paul was referring to the charge pump.
If so, yes. All charge pumps are the same.
