Old 08-09-2014, 07:45 AM
GrotenhuisCubs's Avatar
GrotenhuisCubs GrotenhuisCubs is offline
No wife has been in hospital and we are combining our wheat right now the cub got put on the back burner for a bit!
104 puller, 1200 puller, 1450 toy!
Old 08-09-2014, 07:31 PM
cadzag72 cadzag72 is offline
Both my regular cubs have the opposite problem, the threads in the block were stripped at some point in their past and my elbows keep blowing out of the block under a load.
Ian
Old 08-11-2014, 08:50 PM
garnold's Avatar
garnold garnold is offline
Is it bad to use high temp anti seize when you put one of these elbows on to avoid it from getting stuck?
Old 08-11-2014, 10:27 PM
Default Got back at it!
Got the motor mounted tight and then went to town with a large pipe wrench and got it loose! Thanks guys!
Old 08-11-2014, 11:02 PM
You can yes. Does it help...... maybe. I would.
Old 08-12-2014, 03:15 PM
Darrell Darrell is offline
I also have used alot of PB Blaster and a pipe wrench with BFH , but i had an engine that someone threaded a short piece of pipe into the exhaust outlet and the pipe would collapse with a pipe wrench.
I took a sawzall and cut a slot thru the pipe and collapsed the pipe and it came right out !!
I knicked the threads but not enough to where the the elbow wouldn't tighten up. Use a new lock ring on the elbow.
Old 08-12-2014, 03:53 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I have only had experience with K301's in narrow frames.
The elbows were always turned in hand tight and then the locknut turned in tight to the block.
Not the elbow turned in tight.
I have ad three come to me that way, is that not the standard factory setup?
Old 08-12-2014, 04:54 PM
o---o o---o is offline
Originally Posted by Cubby guy View Post
Kroil,
Isn't this just the best stuff ever? I wish more people knew about it.
Old 08-12-2014, 06:25 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
yes it is, wish it were easier to find. its been around forever
Old 08-14-2014, 09:29 AM
b4pw53pw's Avatar
b4pw53pw b4pw53pw is offline
I've only done one, the best thing is a lttle bit of heat, cooling, penetrating oil and lots of patience! I used a mapp gas torch and never got it red, just uncomfortably warm to touch. Like Alvy said, hold presure on it, tapping from different directions, more penetrating oil and simply working it back and forth once it does break loose. When I bought my 126, it had a stack on it. I was going to take it off, especially after going deaf running a snowblower on it, but decided to leave well enough alone. Now if I want to run hi rpm's for a long time I have a small muffler that slips right onto top of pipe, or i put ear plugs in, depending how mad I want the neighbors to be at me! Roy
I have seen the light!.....oh wait, thats the headlights on my 126!
107, 126
Pincor generator
Haban 402d sickle bar
Brinly rear scraper
snowblower
rear tiller
