Old 09-03-2021, 09:45 PM
Merk Merk is offline
I have a radiator from a 2182 that I'm willing to sell.
PM me if someone is interested.
Project Uncle Dick
Cub Cadet 70
Old 09-04-2021, 10:43 AM
TheSaturnV's Avatar
Could it be a simple matter that the smaller radiator of these two is just not as in as good condition?
My 882 had a case of the heat creeps until I had a local shop rebuild it, using the original tanks. Heat has never been a factor since then. Sometime later I put on a new water pump, and it ran even cooler.
Old 09-05-2021, 03:48 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I put yet another thermostat in the 1572. Counting the original, this is the third one. It is doing better, but if I leave it idling for long, it is liable to go into a thermal event again. Since this has the original radiator, maybe TheSaturnV is onto something and re-coring or rebuilding it could be the ticket to fix it. Thinking more about that, I bought this in 1987 so it has been in this state for 34 years now. Radiator shops are hard to come across now. Most placed want to se you a new radiator.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-05-2021, 07:09 PM
cooperino's Avatar
Originally Posted by FrankF3 View Post
It just occurred to me and I hate to say it, would a blown head gasket behave like this?
If you had a blown head gasket, you would likely have smoke from exhaust and be adding coolant from time to time.
Couple of questions. Are you certain that you gauge and sender are providing accurate temps? When its running with cap off is it bubbling out? Have you checked the water pump? If fins on pump have deteriorated flow would be diminished. I ask because you say it only happens at lower engine speeds. Maybe the pump is able to move enough water at higher rpm
Old 09-06-2021, 01:05 PM
FrankF3's Avatar
I've had no smoke (other than what's expected) out of the exhaust and have not had to add a drop of antifreeze in a few years.
Old 09-06-2021, 01:11 PM
cooperino's Avatar
So not a head gasket.. I would be checking the pump. Thermostats function is pretty simple. You can test the operation of one easily with a pot of water and thermometer on your stove top.
Old 09-10-2021, 12:56 PM
FrankF3's Avatar
Good thought... I have a spare water pump already. Since this one is the original that came with the tractor, I'll swap it out and see what happens.
