Old 08-30-2014, 06:43 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
here are the pix of the bucket. i got the pin to fit better. i still might be be making a new bucket, im not really liking the way this one works with the QA.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 08-30-2014, 11:05 AM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Looks good! Would be awesome to see a vid of the backhoe doin work!!
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 08-30-2014, 08:54 PM
kenny jordan kenny jordan is offline
ken 6x6
that looks like it does on the bigger tractor loaders . I have one concern about your palet forks did you use two motor grader blade bitts for the forks if so you might want to think about using something else them are very brittle and could snap into when lifting something heavy would hate to see that happen and someone get hurt .once again not putting it down you done a great job building it
Old 08-31-2014, 07:57 PM
ken6x6's Avatar
the forks are made from a cutting edge from a dozer. the edge is hardened steel. thats why i chose to use it. since normal forks are hardened too. i put the forks to the loaders max with no issues. thanks for the concern.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 10-26-2014, 03:18 PM
ken6x6's Avatar
well i got tired of the old bucket not working the way i wanted it to. here's the new one i made. used 1/8'' plate and 1/4'' flat bar. took about 10 hours to complete. weighs 145lbs. what do you think.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 10-26-2014, 07:47 PM
bolivier's Avatar
bolivier bolivier is offline
I like it! Looks like a skid steer bucket. You know how they are kind of deep? How was the other bucket that you modified not performing to your expectations?
Old 10-26-2014, 09:59 PM
ken6x6's Avatar
i could not get the mounts high enough to make the bucket curl up when it was flat on the ground. you can see in the pics of the old bucket the cylinders were bottomed out.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 10-28-2014, 10:00 AM
Nice work as always Ken!
Old 10-29-2014, 04:07 PM
Wow that looks great. Great work.
Old 11-02-2014, 08:46 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Did a nice job. The bucket looks to be waaay more than that cub would handle (loaded). I like the whole project. Looks handy.
