Old 09-11-2014, 04:45 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Why does everyone keep saying lean....... you don't get exhaust backfires on a lean running motor.
OK - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich - Lean - Rich - Lean – Rich
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-11-2014, 04:46 PM
c69ss396 c69ss396 is offline
exactly a backfire is caused by excessive fuel. Running lean is caused by lack of fuel... therefore no fuel no back fire....
Old 09-11-2014, 06:18 PM
bolivier's Avatar
bolivier bolivier is offline
Well I can't order parts from the onan site for a few more days. So until then, the tractor will wait.
Old 09-11-2014, 06:23 PM
What about doing a leak down test. Could unburned fuel be going in the exhaust causing it? Just throwing that out there. Onans are known for valve seat issues also.
Old 09-11-2014, 06:36 PM
An exhaust backfire is basically unburned fuel. So, your right about that. A leak down test is not a bad idea. But I think it's a carb issue. Brent said the PO told him it started all at once, so unless a seat came out, I'm not sure it's just wear. Although, PO's do tend to exaggerate, and not always tell the whole truth. I don't think I'd go to the trouble of a leak down test until after going through the fuel system and doing a tune up. Just my
Not a bad idea by any means Todd!
Old 09-12-2014, 12:23 AM
I agree J, I was just throwing that out there. That's what I would also do first (clean the carb). IIRC the one I did I was able to reuse the carb gaskets.
