Old 10-01-2014, 03:29 PM
resto1450 resto1450 is offline
Originally Posted by sawdustdad View Post
I like the ingenuity you've displayed--got to give you props for that. But I agree with Johathan, the original equipment was proven through years of use, and probably more rugged than that coupler. What happens when your deck hits a root and stops your tractor . Will that coupler handle the shock load?
As for straddling that driveshaft, I guess the tunnel cover would protect your essential parts...
The tractor was repowered with a 16bs and I have been making a lot of decisions for new parts as lots I have come across is not stock. Johnny cash would be proud as this thing has come one piece at a time! Lots from the shop after hours. Didn't think I could one up the time tested engineering(learned that while rebuilding an old 8x8argo) , just got caught making a potential mistake. I will get a mounted bearing in there to support the shaft. Coupler specs out to be able to take quite a pounding so I am comfortable there as far as wood chipping.
Thanks for the input! my twins appreciate it
Old 10-01-2014, 04:25 PM
941-3004 Self aligning ball bushing....... $23.75
722-3000 Flex disk coupling..................$13.22
IH-547749-R2 Hydro cooling fan...........$10.73
Shipping.......................................... ...$13.00
Total............................................. .....$60.70
Knowing that the driveshaft isn't going to explode and hurt you........... priceless.
By the time you buy a pillow block bearing and install it you could have fixed it right, for less money and half the time. I strongly suggest, for your safety, that you take off your "repair" and shelf the parts. Buy the correct ones, and start over.
Old 10-02-2014, 10:56 AM
Sounds good. Thanks for the part numerbs. Get those parts from the cub dealer?
Tractor is coming apart this winter for blast and paint, repair some worn linkage, etc. I have one more mowing to do and a couple gardens to till. I think my repair will hold up. I am putting the keeper in there for the little work I have left just in case.
It is getting cold out and new garage needs insulation and heat. I will post pics this winter of the resto work AND the OE drive line parts.
Old 10-02-2014, 11:15 AM
You can get those parts from the dealer yes. I look up part numbers here: partstree.com. I got the prices by plugging the part numbers into this site: cubcadetpartsandmore. It seems to be the place with the best price.
Now, I see a U-joint at the front. If it is rated for 3600 RPM, it will be ok..... but, I thought you said something about a B&S engine in this tractor. I don't know what motor you have, but that is also not factory (motor or u-joint). I suggest talking with JeffinPA and getting a new driveshaft made. Check out his stuff, here, and if you need a custom shaft, Jeff will gladly work with you. (Post #6 is his driveshaft post)
