Old 09-25-2014, 10:36 PM
If you incorporated the tandem hitch into the frame of the first two, and let the rear one "hitched" up then that would work. Only problem is, it will be a bear to store. I suppose you can find a way to make it easily detachable.
I have to say, I'm with Sam. I really think this is more trouble than it's worth.
Oh, BTW.... I LOVE your "cad" drawings above! Wish I had a program that I could do that with.
Old 09-25-2014, 11:55 PM
Berwil's Avatar
Berwil Berwil is offline
Even if it had a caster under the bag it wouldn't work. Unless you mounted the caster to the frame and not the bag. Then it would.
My sweeper has a frame tube that runs along the back bottom edge of the bag, so that is what I was referring to. I guess not all have that.
I do agree about the storage concern. If kept together it will take a garage bay to store, even apart will be half a bay. Then there's the assembly, disassembly every time, tweaking the setup when one is misadjusted, etc. not trying to rain on your parade, but I think I would upgrade to 1 of a larger size and enjoy the seat time.
Bill
Old 09-25-2014, 11:56 PM
Shaner Shaner is offline
Go to northern tool and buy an estate rake. Then windrow your yard, and sweep up the windrows.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 09-26-2014, 12:38 AM
With one of these!!! LOL!
Takes care of a lot of issues! More area to store grass, so you don't have to dump as often..... you already have the sweeper.
Old 09-26-2014, 09:21 AM
jimbob200521's Avatar
lmao thanks! Just so you know, you have the exact same program on your computer I used to make those "drawings" with. Just a few minutes in Paint and violla: you have some rudimentary drawings
Attachment 56844
That was my other thought; find a way to increase the carrying capacity of the lawn sweeper. Some areas I want to do I can't even make a full round without getting a full load. I need (ok, well, let's face it, WANT ) a way to pick these big "windrows" of grass without stopping every five feet to dump.
Bill
Storage wouldn't be a HUGE concern; I'd got a little shed out back, as long as I could reasonably remove the sweepers from the frame, I'm sure I could store it in there, especially if it's only two sweepers.
-Ryan
Old 09-26-2014, 10:12 AM
A hand held leaf blower mounted red green style would do the job, then when you get a big enough row, go to the sweeper.
