Old 03-28-2015, 08:29 PM
jbrewer's Avatar
jbrewer jbrewer is offline
That tank looks fantastic... there's a lot of "stuff" under the sheet metal of your 782 Georg, you've done a very very nice job!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-28-2015, 08:36 PM
Very nice Georg!
You won't have trouble with the fuel gelling in the winter.
Sie werden keine Probleme mit dem Kraftstoff Gelieren im Winter!
(I used a translater.... hope it worked! )
Old 03-29-2015, 06:13 AM
ihc353s's Avatar
ihc353s ihc353s is offline
@Joe, the Fuel Cab is similar to the VW Rabbit. This one is a little smaller and comes from an German Motorbike Brand called "Zündapp". Zündapp were closed in the eighties and sold to China.
As next, i need a Hole for the Fuel Cab, Paint and a strong Battery, and i can make my first start.
And Yes, the Translator works,(:-)
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 03-29-2015, 12:01 PM
red56turbo's Avatar
Georg,
Wow, she's come a long way and looks great! The tank fits like a glove. Nice job.
Josh
Diesel Cub Cadets...........
Old 03-30-2015, 12:09 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Georg,
REAL NICE job on the conversion. The tank design is awesome!
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 05-10-2015, 05:40 PM
ihc353s's Avatar
The Tank is ready, and the Diesel is running like a Kitten,
Old 05-10-2015, 05:43 PM
That is great Georg. I am glad all turned out well for you.
Old 05-10-2015, 11:47 PM
Nightow1 Nightow1 is offline
Originally Posted by TheSaturnV View Post
Georg,
Will your battery stay under the seat? Be aware that the Kubota D600 is very sensitive to having a strong ground. There is a factory bulletin on adding an additional ground of large gauge wire (I think 4 or 6) to the original ground. I hope your battery isn't too far away from the starter, etc.
Nice project!
I dont know if this will help, but back when I i use to race 1/4 mi? We would use a 5 point ground system. Cant see why it wouldn't work on a cub. Guarantee it would fix any ground problem.
Old 05-31-2015, 04:06 AM
ihc353s's Avatar
Yesterday, the Diesel was ready for the first Mowing Job. The Motor and the Hydro System got new Oil and Filters.
I use the white Side Panels, because it has Holes for the Air and the Exhaust, and i think the new Design will make him pretty(:-)!
mfg Georg
Old 05-31-2015, 10:00 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Great job. I like the different look of the side panels in white. It matches the car in the background too.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
