Old 11-04-2014, 10:02 AM
Yes price...
Up to 534 and counting...
Old 11-04-2014, 12:01 PM
red56turbo's Avatar
Yes price...
One Bennie, two Bennie, three Bennie, four.................
Josh
Diesel Cub Cadets...........
Old 11-04-2014, 07:31 PM
I worked on getting this running today,replaced the bad s/g,new points,plug and gas line.Carb was clean as I pulled the main jet needle and it came out without any gunk on it,at least the fuel pet cock was shutoff cause there was some gas in the tank.
Turned the key and the hour meter,headlights,tailights worked,turned it over and gave it a choke,started right up....but! funny noise coming from the internals,sounded like the balance gears,shut down and drained the oil and a few teeth fell out...
So looks like I have to pull the motor,hopefully some damage was avoided.
On a lighter note,the amp meter shows a charge
Old 11-04-2014, 07:44 PM
kostendorf's Avatar
Fork = balance gears
Sounds like you got lucky besides the balance gears Lew, good luck.
Old 11-05-2014, 07:25 AM
mickb72 mickb72 is offline
Default cub
Hi Lew, dang, i didn't think those 169's would have had balance gears. I just took balance gears out of 12, one gear had marks from rubbing something. The crank i guess. It looked like it had 70# oil, for the noise i guess. I was hoping for a used motor, no good, skeeter fogger, must have been a real dog with 70# oil, even the governor was set more sensitive and the rod dipper looked like a banana. It ran pretty good after removing all those restrictions but was a smoker, needless to say the man who was selling me a good used motor got it back. Mike
Old 11-05-2014, 05:26 PM
Originally Posted by mickb72 View Post
Hi Lew, dang, i didn't think those 169's would have had balance gears. I just took balance gears out of 12, one gear had marks from rubbing something.Mike
Yes they have balance gears, took them out today, one was sitting on the bottom of the oil pan.I got lucky, not dipper damage, just a few worn teeth on the crank.
I will wash the inside of the block with brake cleaner,oil up everything and reinstall the pan.I will put a magnetic oil pan plug on it.
See how it runs without the gears.
Old 11-05-2014, 05:38 PM
Looks like you dodged a bullet buddy.
Some days even a blind squirrel finds a nut.
Old 11-05-2014, 06:32 PM
Agreed Sam, looking good lew.
Old 11-05-2014, 07:34 PM
Congrats on the 169 Lew! Glad to see you got yourself one.
Good to hear you dodged the bullet and getting it shut down in time.
