Old 11-21-2014, 08:16 PM
Originally Posted by Berwil View Post
I got to the bearing store the other day that Jeff mentioned and I went on a spree. I got new gearbox bearings/seals, snap rings, transfer shaft bearings, input pulley for 1/2" belt, keystock, and never seize for $75. I thought it was too good to pass up. I got the bearings and seals in the box installed yesterday. I installed the output shaft and maybe because the seals are the tiniest bit thinner, I have 1/16" of end play in the shaft. I'm wondering if I should shim this out? I know that raising and lowering is going to be moving it in/out a lot unless I shim it. Any thoughts?
Attachment 59001
I also found a hole in the tube of the transfer shaft end of the driveshaft. After looking at the manual I see they say there is a lube point there. I figured there was supposed to be a zerk there so I measured the hole with a drill bit, 13/64. I ran a 1/4-20 tap in and whadaya know....it had threads already. Need to add a zerk to the list.
Bill
Rut roh, zerks are 1/4-28 NF
Bearings and Drives Unlimited has pretty good pricing
Old 11-21-2014, 11:51 PM
Berwil's Avatar
Berwil Berwil is offline
Doh'
Guess I'll run the 1/4-28 tap through and add some loctite. If that doesn't work, I can always close this hole and drill and tap a new one. I've made worse mistakes.
I was surprised by the prices, saved a bunch and I walked out with it!
Bill
Old 11-26-2014, 12:21 AM
Berwil's Avatar
Update, I've made pretty good progress. I got the gearbox bearings and seals in, shimmed out the output shaft end play, packed the box with hi temp ep grease and 80-90 oil. Turns nice and smooth now. I fixed and installed a new zerk on the driveshaft and attached it to the gearbox. I painted everything over the weekend and finished up last night. I'm hoping to assemble the bulk of it this weekend, I'll try to grab pics as I go. Of course in the meantime we are supposed to get hit with snow tomorrow. Anywhere between 1-8" depending on who your watching. I spent an hr this evening digging out the O from the back of the shed, taking the deck off and installing the blade. I haven't run it since the middle of summer, but on the 6th chuff it fired up, I love that thing! Here's a pic of my progress, painted parts all over and a sentinel on guard.
Bill
Old 12-01-2014, 05:21 PM
ab147's Avatar
ab147 ab147 is offline
nice job on the rebuild. Just yesterday I took off the discharge chute on my qa42 and took all the paint off, and am waiting to get some primer and repaint it. Good tip on the appliance paint I was thinking what kind to use. Thanks. Wire wheels aint bad to use, I've got one about 3in in diameter running on a milwaukee angle grinder, works good.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 12-05-2014, 05:51 PM
Berwil's Avatar
update:
Turns out I got sick last weekend, didn't make much progress at all. This week I got the auger with new greasable bearings in, spins great!. I got the chute and drive gear on. I was going to put the new jackshaft bearings in, but I noticed they didn't have a grease hole like the originals. I went back to the bearing place and will have the correct ones in a few days. Once I get those I can finish up work on the housing. The QA mount is essentially ready to go,
Here are some pics, its starting to look like a snow thrower again.
Bill
Old 12-05-2014, 08:32 PM
That look really nice Bill. You're not really going to use that are you?
Old 12-06-2014, 08:03 AM
cubfan's Avatar
cubfan cubfan is offline
Nice work, looks great.
Old 12-06-2014, 08:41 AM
update:
Attachment 59462
Attachment 59463
Bill
No, it's starting to look like a brand new snow thrower!
Old 12-06-2014, 09:56 AM
Wow, it is essentially BRAND NEW!!!! great job on that....
Old 12-06-2014, 03:35 PM
Berwil's Avatar
Thanks guys, but I have to admit it is a 5' paint job, the phone pics help hide the imperfections.
It should work like new when I'm done, all new bearings, seals, chain and repaired housing. I got lucky a little side work came my way and I could splurge on everything. Now if only it would stop raining so I could get the leaves takin care of and the deck off the tractor.
Jeff, I would say of course I'm gonna use it, but we all know that now that I have this rebuilt, it won't snow......you guys are welcome.
Bill
