#21
I don't see any posts here that indicate frustration......
#22
Once again, we'll just agree to disagree and I'll leave it at that. Sorry OP, back on topic.........
![]() Loader, Can't wait to hear what your troubleshooting finds out.
Josh Diesel Cub Cadets........... |
#23
OK this time with a pic. The pic shows what a disconnect clutch looks like. This was in a 1572, not sure if the 1512 had this or not. I looked at the drive line on parts tree and didn't see it. Anyway the disconnect clutch is pointed out with the red arrow. What you need to tell us is if the pump input shaft is turning while the engine is running, it's pointed out with the green arrow.
#24
The 1512 drive shaft is a solid rod, no disconnect. Here is my factory shaft, and other components.
3 original cubs 1512 diesel Ingersoll 3012 John deere 855 |
#25
I think I had said earlier it came out with one..... that was my mistake. Some of the diesels did and I thought the 1512 did. No, it was an option for it, but not standard equipment. |
#26
Loader, Any time to dissect your problem and update us with what you found?
#27
I checked the pin at the pump. I punched it out and put it back in. It's intact. Then I thought about an earlier comment about how I wouldn't be able to turn the engine over that easily and there could be a disconnect. I looked for that. Thanks for the picture and no, mine doesn't have that. It is a solid shaft as pictured. It does have double rubbers at both ends. I remember that I did that years ago because it was eating them. I pulled the shaft to inspect everything and the pin at the engine end had sheered off. For some reason that broken pin did NOT want to come out! I do have the shaft rebuilt but ran out of time to complete reassembly. I hold high hopes that everything will be functioning perfectly when I get it back together. This is why I come here. You guys saved me a great deal of time as I was preparing to pull the rear and tear apart the pump. I would have left the shaft in place and gone through a great deal of trouble and expense for no reason. I'll update you when I know for certain. |
#28
Sounds like you found the problem. Keep us posted.
#29
Thanks for the update.
If you can find a distributer of those coil pins besides cub cadet, buy some extras they are a wear item. Cub distributors are pricey for them. Here is a post from Sam Mac from when I needed pins. McMaster http://www.mcmaster.com/#95755a419/=u9lmkc then look up part #95755A419 Cub Cadet 915-3000 Pin, 1/4 X 1-3/8 Hvy Cld Spr
#30
Glad you found the problem Loader and it was fairly simple. Worse part about it was pulling the driveshaft to get to the front pin I'm sure.
