Old 12-13-2014, 12:24 PM
Pics of the two different bulb styles.
Old 12-15-2014, 05:14 PM
Group_44's Avatar
Group_44 Group_44 is offline
I have been following this thread with some interest since I have replaced two of these grilles in the past couple of months. I gave the old ones and the new replacement a good look and here is what I found. The older round headlight style and the new round headlight replacement appear to be identical in construction including the material thickness. The halogen headlight style is close but lacks an important re-enforcement on the bottom near where it bolts to the frame, and most of the ones of this style that are cracked are always cracked in that area.
Old 12-15-2014, 06:21 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Great info guys. I will definatly be buying one of the newer year grills. The last two posts show it's the better design in my eyes. With the lower mounting area being so small no wonder they break. It would be so much stronger if it could be metal. What about the idea of not making an entire grill and just making only the lower mounting area out of metal and having the factory grill with the old lower mounts cut off bolt on to the new lower mount. I'm not sure it would be possable but just a thought. It would be cheaper to make just the lower mounts than the whole grill.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 12-15-2014, 07:20 PM
Great job of showing and explaining the differences in the grill styles.
Old 12-15-2014, 08:34 PM
Group_44's Avatar
That means a lot coming from the master. This thread inspired me to really take a look at the different grilles I had been working with. Since I had all three styles in the shop at one time a few pictures seemed in order.
Old 12-17-2014, 02:20 PM
markmdz markmdz is offline
I don't have access to my tractor at the moment. If someone has access to their, can you measure the approximate dimensions of the grille?
Old 12-19-2014, 01:09 PM
Group_44's Avatar
What are you looking for as far as far as dimensions, the grille isn't exactly a rectangle? I have a couple on the workbench if there is a specific dimension you need I can try to get it.
Old 12-21-2014, 07:12 PM
Basically just rough outer dimensions. Kind of like setting it face down and looking at the longest length and width, as well as the highest point. This is all to determine how large of a casting box would need to be used to make the piece.
I've been looking mine over, as well as your pics, and there's a few spots that I'd want to reinforce, as well as just making the wall thickness a bit more if I were to have it done in aluminum. Again, this would all be solely to make them more stout and allow someone to be able to push the tractor from the nose, as well as not have to worry about it being too fragile when doing anything with it.
(No, I don't intend to beat the tractor up, but when I'm mowing close to thick brush or near small tree limbs with my 100, I don't even concern myself with what brushes in front of the grille. Having said that, I'd never use the nose of the tractor to push something, nor intentionally put any stress on the nose.)
Old 12-22-2014, 10:18 PM
bugeye bugeye is offline
Rough 19" high, 19" wide, 7" front to back.
Old 12-23-2014, 12:53 PM
very cool. thank you.
