Old 12-22-2014, 09:36 PM
cubfan's Avatar
cubfan cubfan is offline
Learned my something new for the day too.
Old 12-22-2014, 11:03 PM
bocephus1991's Avatar
No problem Daniel, I was just curious what happened to the engine.
Brian
Old 12-22-2014, 11:46 PM
snoel's Avatar
snoel snoel is offline
I think that the main flywheel difference (if any, in small vs. large) will only be noticed at low RPM. At high RPM, the power pulses are closer together (time between), and will carry the rotation through. Low RPM is when torque carries the load. High RPM, horsepower is the "beastie". All technical terminology, that really is not important to understand, in order to get these machines out there and get some work done!
Steve
Old 12-25-2014, 01:21 PM
Talked to dad today..he said the 12 hp flywheel didnt have enough mass to keep the engine spinning right. It was hard to set the timing and it melted the piston because he never could get the timing right. Keep in mind he is a 40 year I.H. Mechanic.
Merry Christmas.
Old 12-26-2014, 01:04 AM
I don't think that's what caused the piston to burn. I had a 30yr IH mechanic also tell me to run full synthetic oil in my k301 and it wouldn't burn oil. Please don't take this wrong. I doubt it highly that the smaller flywheel caused that. I did it on my k321 , timed it fine ran fine. Mowed three different times with it for a total of 9 hrs running at wot. That's my 2 cents.
Brian
Old 12-26-2014, 01:49 AM
I too doubt it was the flywheel. Nor am I doubting your dads knowledge/ability. But, the mark on the flywheel would still be correct. Small or big they are keyed the same. Not sure why the timing was difficult to set, but I'm certain it wasn't the flywheels fault. Unless it was from another application. Something is amiss. Even if the marks were in the incorrect spot, you can use a degree wheel to make a new one or find the correct time.
Old 12-26-2014, 01:32 PM
Yeah, I'm not sure either. I saw him yesterday so I asked him and that's what he remembers. The comment about the experience was to set context about his experience and knowledge acquired about working on Cub Cadets. It just didn't work out for him for one reason or another; that's ok, and I'm not offended or concerned about it.
Old 12-26-2014, 01:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
timing marks are the same, if you can set it on a 10 or 12 you can set it on a 14. only concern I would have is mowing on a 100 degree day for long periods of time. the bigger wheel moves more air. but if you keep the cooling fins and screens clean it shouldn't be an issue , I prefer heavy flywheels myself.
Old 12-26-2014, 06:47 PM
Originally Posted by garnold View Post
You picking on me Sam :-(
Yeah, maybe a little.
I probably shouldn't have, but keep in mind that I pick on everyone the same... I'm an equal opportunity picker.
Old 12-26-2014, 09:22 PM
donald EDWARDS donald EDWARDS is offline
Thanks folks to all who replied, OK the 14 HP will be going in the 108. HappyNew.
