Old 01-01-2015, 09:07 AM
It will probably wind up in the weds along side a road somewhere.
Old 01-01-2015, 01:31 PM
bocephus1991's Avatar
I was wondering what he was thinking when he said the piston wasn't moving until and down and he was looking in the spark plug hole! That engine could probably been saved don't know how bad the pitting was in the cylinder walls. Soak it in a 50/50 mix of atf and acetone , a last resort would be remove the piston in pieces. Not break the block apart! It all still amazes me. Im not hating on him stints or no stints!
Brian
Old 01-01-2015, 02:15 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
No
He is a scraper.
One video shows how he uses a skil saw to cut up helo blades for the scrap yard.
Probably why he had no qualms about smashing the cylinder block with a hammer.
It is all just metal to be scrapped if it is too much effort to save.
Old 01-06-2015, 12:14 AM
jcsmith jcsmith is offline
What a slob.
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 01-06-2015, 08:45 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
It looks more like a Demolition Derby rather than a Cub Cadet Restoration! I bet he has a specialized hammer for each type of work he needs to do.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 01-08-2015, 07:16 PM
BCDSFCRET BCDSFCRET is offline
Default bcdsfcret
That is what you call a "Hammer Mechanic"!
Brian
Old 01-09-2015, 10:59 AM
dbuck dbuck is offline
That Guy is a complete moron. I could only handle about 20 seconds of that. I happen to know a Guy that thinks a 20 lb sledge is his best friend, when some thing goes wrong with a piece of his equipment. Maybe pair them up and they could be the dynamic hammer duo.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 01-09-2015, 01:28 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
Originally Posted by DoubleO7 View Post
No
He is a scraper.
The few scrappers I have know are a few cards short of a full deck.
Old 01-09-2015, 04:14 PM
austin8214's Avatar
Burning to much wire insulation will do that to anyone.
Old 01-09-2015, 05:17 PM
DoubleO7's Avatar
Or standing down wind of the melting pot of old lead-acid battery internals.
