#21
#22
Says he already had an offer for $1750. Guess he will regret not jumping on that. But then again I have seen stuff go for stupid money in the last couple hrs of the auction.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#23
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#24
wow
#25
If it has yellowed the plastic is lexan which shouldn't be fragile, if it's acrylic then it is more likely to be fragile or break, but wouldn't yellow. Guessing early lexan, (polycarbonate) that stuff really yellowed fast, modern poly has uv coating on it.
Wouldn't think the original idea would be for a yellow background? But can't remember seeing one back then, just a guess but would say it's not older than 1970 - 75. Daulite has kicked out a ton of cookie cutter signs for national accounts over the years. Retail now to make if from scratch would to be around $2,500.00 but from Daulite because they made hundreds that size and used the same molds for the faces would be considerably less. Just my opinion, finally something I know a little about, been in the biz for almost 25 years. Vic |
#26
Current bid $1427.56
Vic, I believe the yellow was on purpose. Seller claims it was for construction equipment sales, industrials were painted yellow, I assume it's a tie in. Interesting about the different types of plastic though. Bill |
#27
$1,526.67 with one hour nine minutes to go.
#28
US $1,526.67 [ 17 bids ] Got greedy and lost out on that $1750 offer
#29
No snipers! I'm surprised!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
#30
Agreed!
I'm suprised too!
