Old 01-19-2015, 08:32 PM
If you look at the CPE snowthrowers,parts breakdown for the qa42a it shows that hole.not sure why it us there.
Up to 534 and counting...
Old 01-19-2015, 09:00 PM
I will confirm that. I have one to look at, plus the parts book.
Old 01-19-2015, 09:12 PM
As far as mysterious extra hole in the mounting plate,
IIRR they made a 3 bolt mounted gear box ?? would that be for that bolt pattern? just thinking out loud.
Old 01-19-2015, 10:33 PM
The QA's used the 3 tab gear box, but the the QAXXA's used a four. Your probably right, it's just for the 3 tab box. I honestly don't see why they wouldn't interchange. In this case, my guess is that the PO drilled the holes in the wrong spot. Or perhaps that mounting plate was even reproduced....... incorrectly.
Old 02-06-2015, 12:04 AM
mch19w mch19w is offline
Default QA36A snow thrower on a IH 147
I had the same problem putting a QA36A on my IH 147. The belt was rubbing on the left side as you look at the tractor from the front.
On my snow thrower the bar that the whole thing pivots on is 2 5/16 longer then the bracket. I was going to put a piece of pvc pipe on there for a spacer or bushing, but thought it might be to ridged and maybe crack a weld under the stress of operation. So as I was walking into the shop I spotted an old washing machine drain hose. You know the one that has a u shape at the top. I wacked 2 5/16 off of it. That gave just enough, and I mean just enough space to operate without rubbing, Its hard to see in the photo's but there is about 1/8 of an inch in there for clearance.
The manual mentions some sort of adapter for machines with serial numbers under 400,000 or some crazy number, maybe this is it! Good luck.
