Old 01-25-2015, 09:20 PM
hogfly hogfly is offline
Default grease
so remove the vent installe zerk fill full of grease remove zerk reinstall vent and good thanks for any help men
Old 01-25-2015, 09:24 PM
No..... you can't do that! You'll blow the seals right out. You have to put a zerk in the side. Drill the case, thread it, screw a zerk in. Then LEAVE IT. You can't just put a zerk in the top hole and pump.....
Old 01-25-2015, 09:35 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I used a needle on my gun to squirt some in.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-25-2015, 09:37 PM
That might work.... I'd squirt a lot in though. After seeing what was in mine after the break down, (virtually nothing) I'd keep as much in there as I could.
Old 01-25-2015, 09:40 PM
Default zerk
hey jon this is the 1st year i used it i bought it in pa. you hooked me up with the guy thanks again i used it one time so far it worked great i checked housing temp while it was blowing stayed cool i am not opposed to drilling the box this spring but do you think it will make it through winter no sighns of leaks and should i put fluid or grease back i know you say 50/50 but can i use fluid so i can check level thanks kenny
Old 01-25-2015, 09:45 PM
Shrewcub's Avatar
I did it when it was warm out side. Grease doesn't like to move very well at 20 degrees. I squirted until it came out the top. After an once or so of 80-90. Did fine for the 2 hours I used it a couple weeks ago. Full tear down coming this summer.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 01-25-2015, 09:46 PM
I'd do what Shrewcub suggested.... use a needle fitting to squirt some grease in. I honestly don't think it would hurt to put some gear oil in it too. Then you'll have the 50/50 mix. Just check the box before each use until you know it isn't leaking out.
Old 01-25-2015, 09:56 PM
Default grease
thanks guys i will keep you posted on it
Old 01-28-2015, 05:45 PM
Ikea6e Ikea6e is offline
Default 451 Snowblower Gear Lube
U use a 50/50 mix of oil and grease. I use Marathon EP2 grease and gear oil. Same thing as I use in the snowthrower gear boxes.
Thanks Jon,
Do you use the same mixture for the gear box that drives the impeller?
Thanks,
Ike
Old 01-28-2015, 07:02 PM
Originally Posted by Ikea6e View Post
Thanks Jon,
Thanks,
Ike
Haven't yet, but going to. I need to disassemble it. I haven't taken the main box on the 450 apart since I bought it.
