Old 02-12-2015, 03:06 PM
RLause's Avatar
RLause RLause is offline
Hello. Here is a link to the original 149 sales brochure that might help with the paint colors.
http://www.cubcadetcollectors.com/fo...etail&df_id=28
Richard
Old 02-12-2015, 05:13 PM
zimm17's Avatar
zimm17 zimm17 is offline
Richard
Very cool! Thank you. It looks like all my colors are correct except the seat mount needs to be yellow. Prior owner probably bolted on a whole new seat assembly...
I took the wheels in to have the tires de-mounted. I'm buying paint tomorrow and hopefully will get the wheels sprayed and tires mounted. I have new 23x8.5-12 Carlisle tri-powers and I'm moving my firestone tri-ribs over from the sears tractor.
New battery waiting to go it. New tail light lenses that snap right onto the existing light bases. I lost the built in reflector, but for $2.50 each instead of $30 for used, it's worth it. I actually bought whole new lights and just used the lenses as it was the nearly the same price using amazon rather than paying $10 shipping for $4 worth of lenses from an RV store.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 02-15-2015, 09:53 AM
zimm17's Avatar
Yesterday I bead blasted, sanded and painted the wheels and weights. I found IH weights on craigslist an hour from me. Tune up kit and new battery installed too. I'm going to attempt to mount the tires today.
Think it was time for a filter?
1973 Cub Cadet 149
Old 02-15-2015, 12:15 PM
Looks good zimm17 and yes that filter needed replacing--not a day too soon!! But why didn't you repaint all of the rims---the inside part? To me, repainting just the part that is visible is like a smoker who uses tooth whitening agents....they only fix what shows but what about the condition of the inside, which to me is far more important.
Also, before you remount the tires, are you using tubes? You may want to as the moisture from the air is corrosive over time to the inside of the rims.
Old 02-15-2015, 12:22 PM
zimm17's Avatar
Yes I'm using tubes. The painting conditions were terrible- 45 degrees, howling wind, had the spray cans in a pot of warm water, and the portable heater to warm up the parts. If I did it all over again... I would have at least used primer on the insides of the wheels. The case/IH paint doesn't cover as good as rustoleum, but it sets up thick.
I wrestled the front two tires on. The 4 ply ti-ribs are STIFF. I had to use a vice to squish the sidewalls to get them on. I did bone up the paint on the insides of the front- that will require some touchup. But since it's 10 degrees outside, that'll have to be another day.
The next "issue" is that my wheel weight bolts are too long! After I blasted, primed and painted them. I need to buy some shorter ones. (parts guide calls for 5 1/4"). Mine are 6". I can get 18-8 stainless from mcmaster carr for $2 each (316 stainless are $8 each! ouch). Or should I just run them as-is with two washers?
1973 Cub Cadet 149
Old 02-15-2015, 12:44 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Why not just cut the ends off?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-15-2015, 12:46 PM
zimm17's Avatar
Well that would save me $38 in hardware.... Let me get the angle grinder out.
Update- complete and looks pretty good. I had a heck of time with the rear tire- ended up popping the tube. I'll take it over to the tire shop Monday for proper mounting. Now to pack front bearings and at least get the front wheels on. Then pull the tunnel and install new hydraulic pressure release thingy to the lever.
1973 Cub Cadet 149
Old 02-15-2015, 04:59 PM
Cubster1 Cubster1 is offline
Nice looking 149. Hopefully I have some motivation and time this summer to do some painting on the 169 and blade.
Old 02-15-2015, 05:06 PM
Since your spraying with a gun I'd look into the case/IH paint, I use it on my tractors and it sprays nice and has a real nice shine to it.
That surprises me.
The old iron guard enamel is ok.... it's better than say Van Sickle. But it's not great paint. It fades with time pretty bad.
Old 02-16-2015, 11:11 AM
zimm17's Avatar
I got the tunnel stripped, primed, painted, and new decals. I'm glad I saved it when I did, it was almost rotted through at the front corners!
New heavy duty hydraulic release spring:
1973 Cub Cadet 149
