Old 02-21-2015, 08:40 PM
Most of the trees are scratch built. The mountain trees are pillow stuffing made into balls, sprayed w spray adhesive, coated with ground foam and cut in half then glued down. Its supposed to recreate a forest of tree tops.
I get some small twigs from my backyard for real wood look(guess you could call that the original "yardstick"), and spray a 50/50 (Elmer's glue and water adhesive solution) on and roll in the ground foam to desired consistency--recoat as desired.
I would love to see a larger picture of you layout. It sounds really neat!!!
Old 02-21-2015, 09:38 PM
Did you see my video?
Old 02-21-2015, 09:47 PM
No....going to check it out now....
EDIT: Hey, that looks really cool. I like the dual sides of your scenery and you lit Exxon sign. You did a very nice job on your layout!!
Old 02-21-2015, 10:52 PM
bocephus1991's Avatar
That's pretty cool! You do very good work! Thanks for sharing!
Brian
Old 02-22-2015, 09:06 AM
Dan,
Were inspired to git into model railroading by the rail that goes by where Dad works?
I thought about that while @ a boring meeting @ F.bureau across the street, a couple of weeks ago, as the trains rolled by.
Hard to think about spring crops, while temps are in the minus range and snow on the ground.
I have the patience but not your creativity for building any models from scratch.
Your setup looks nice, to put it mildly.
One day, it will be as extensive as Blissfield's, if you keep at it. Ha,LOL!
Old 02-22-2015, 09:51 AM
i love model rail roads and hopefully someday i have a house with room for a layout. heres a video from a local train shop that closed down a few years back.
https://www.youtube.com/watch?v=cuI6YRH9QHU
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-22-2015, 11:27 AM
Dan,
I have been surrounded by trains my whole life. I used to live near where that rail line is that you speak of. I actually took a train ride this summer from Allen Park to Ft. Wayne behind the NKP 765 that took us right past Archibold Equipment and through my small hometown of Sand Creek. http://youtu.be/pPKihr0M3uU Dad had a Lionel set up in the basement that we used to run occasionally. I got my first train set about age 14 and it's been downhill from there. (Dad no longer works at Archibold farm supply he's at the turf & contractors building now.) I've seen the MR in Blissfield and there is a lot of talent and a lot of $$ in that building.
Old 02-22-2015, 12:10 PM
Daniel that is a really cool set-up! Neat to see your "other" hobby!
Old 02-22-2015, 12:18 PM
In my back yard......with her sister.......
https://www.youtube.com/watch?v=dkvVdWrlB1M
Old 02-22-2015, 01:13 PM
red56turbo's Avatar
Dan,
Pretty cool. My other hobby is model railroading as well. I run N scale due to space. My layout is 12X9, around the walls with a center peninsula and unfortunately, two liftouts for doors. Just started putting it together in November. Was finally laying cork roadbed this weekend. You're much further ahead than me. My son is into it, too. Great father/son time. I grew up around Santa Fe, then BNSF and now live next to the UP line. Can see the trains from our second story.
Nice job on the dealership. You should run a siding to deliver tractors and such. I think we need some more pics of the layout and vids of trains running. Are you running DC or DCC? I'm gonna go DCC and use the NCE PowerCab throttle to start out with. Thanks for sharing.
Under edit: Saw your vid. Nice layout! Love the steamers.
Josh
Diesel Cub Cadets...........
