Old 02-23-2015, 09:01 PM
Originally Posted by Guitar Guy View Post
I've tried swapping out the condenser. Didn't help.
With a new one?
What about that solid state regulator that someone mentioned above. Does anyone know how it acts when it's going bad?
That's for the charging system. Not going to affect the ignition system. If it was bad, and leaking AC voltage, you'd be frying batteries, coils and condensers left and right.
Old 02-23-2015, 09:56 PM
Guitar Guy Guitar Guy is offline
Yes, I've replaced the condenser & coil with new. The points were fairly new when this started last summer, but I did pick up new points & plug today ... not to be throwing parts at it, but it's due for those anyway, and they're cheap ... so I can eliminate them until it warms up to do more.
It's been sub zero around here, and ice everywhere, so it's not convenient to run it around and get it into "shut down" mode, to check the spark. That's why I'm getting all the info. I can from you guys online while I'm stuck inside.
J Mech, thanks for your input, and your thoughts about the plug wire, regulator, etc. It helps to rule them out. I always appreciate reading your posts - because they always seem to make sense.
Josh
Here's a pic of the perpetrator, from last weekend. Aside from the stalling out routine, it's been plowing snow like a beast this winter, even without my chains. Surprised me what it will do.
[IMG][/IMG]
Old 02-23-2015, 10:03 PM
bocephus1991's Avatar
Good looking 1000! I bought a cheap coil a few years ago mowed three times and it quit. I remember dad replacing the coil On the 1200 once too and the new one from napa was bad. You'll just have to wait till you t dies and test for spark.
Brian
Old 02-24-2015, 12:56 PM
j4c11's Avatar
j4c11 j4c11 is offline
The Bosch 00012 blue coil has a good reputation for quality and durability, I used it to replace the old one that died on my 1450. No troubles since. Of course, the price more than doubled on Amazon since June when I bought it.
Old 02-24-2015, 06:34 PM
Thanks J4C11, that's good to know. Seems a lot of folks are saying they've gotten bad coils out of the box from NAPA, so I guess that could have happened to me.
JT
Old 02-24-2015, 06:48 PM
Any coil can be bad out of the box.
Old 02-24-2015, 08:10 PM
fleetlines's Avatar
fleetlines fleetlines is offline
I had issues I thought were temperature related too. Replaced the coil with the right one from NAPA and moved on. Turned out I shouldn't have moved on because the new coil was bad. I finally got another coil (same model) and all was well. IIRC a coil can work well at some temps and when the temp changes it can cause something inside to loose it's connection.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 02-24-2015, 08:26 PM
A helpful link for testing coil:
http://www.onlycubcadets.net/forum/showthread.php?t=11
Old 02-25-2015, 09:30 PM
Thanks again guys. I'm hoping to get time to work on it again this weekend. I'll update when I get it figured out.
Thx for the schematic DX3 ... good to have, I bookmarked it.
JT
