#21
Today was a good day,got a new front seal for the pto end and installed it.Put the motor back in and fired it up.It runs and drives like a 350 hr machine.I am happy,now just need to fix a issue with the steering column and put the plastic back on.
#22
Lew, you had a busy day! Wish I would have gotten that much done!
#23
Yes it was a busy one.
#24
Lew, couldn't you take that plate off to make room to have that piece welded back on like I did with my KT?
I know it's a different mount, but would be more stable.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#25
Lew doesn't take his time. Moving right along!
Good to see all this progress! Grass is coming FAST.
Tankman '95 CCC 1641 Eastern PA USMC |
#26
Took the steering column out today and found a few chunks out of the steering gear,I had a bad column from an 1810,so I cut off what I needed and made a new stubby shaft.Filed down two flat spots in it and drilled a hole.Rebuilt it and will install tomorrow.
I had a JD one that had bad threads, but it was hollow.They make the races for the bearing a little beefier.
#27
Todd,whole different setup on the briggs,I was able to get the bolt on the stud I JB welded pretty tight,all is well.
#28
Lew you are Da Man! Why do I think the Cyclops are growing on you?
![]() Seriously glad to see someone that has the ability saving them. You'll enjoy the 1641 when your done with it. They are very underrated.
#29
Sam,
This 1641 will make someone a nice grass killer,I am a NF guy,but all I can find are these so I have to make do. I wonder if the motor will fit in a 582 Ih cub cadet?
#30
Today got the1641back together,needs a hydo adjust but everything else is fine.Took a group picture with his big brudder,as he is possibly going away to a new home this weekend.
