Old 04-13-2015, 08:49 PM
It looks like a great cub that was very well maintained. Even so, those valves can stick if the cub sit for a while. Lots of great advice here and great fellas. I'm glad you got a nice cub and deep down, I bet your uncle is, too.
Old 04-13-2015, 09:29 PM
johns cubs's Avatar
johns cubs johns cubs is offline
Thumbs down
Brake fluid? Explain that one....
Something an old farmer told me to do with a stuck valve on a model T. Worked like a charm!! ATF usually works too. But i had a solenoid in a auto trans for OD stickin and i put bout a cap full of brake fluid in that and after drivin a little while it started shifting much smoother. Why it works? Not sure just know it seems to. Unless i have had one hell of a chain of coincidence over the years!!
John
Old 04-13-2015, 09:56 PM
johns cubs's Avatar
Congrats! Love to see old machines working again!
John
Old 04-13-2015, 11:58 PM
Brake fluid makes rubber seals and gaskets expand so more than likely your clutch pack sealing rings on the trans were affected by this or possibly the o rings on your solenoid valve if the bore was worn or something, both of which are a very temporary fix. I have never heard of mixing brake fluid to clean out things like valves but ATF in the oil for a bit yes. I'm going to look more into this, interesting to say the least
Tags
1250, cub cadet 1250, hydrostatic, transmission
