Old 04-27-2015, 12:19 PM
Since the Solenoid is mounted to the Pedestal, it is imperative that not only there is bare metal where the solenoid mounts, but also where the pedestal mounts to the frame. There has to be a continuous ground path back to the Negative Battery Terminal.
Old 04-27-2015, 12:39 PM
TigerCub's Avatar
TigerCub TigerCub is offline
The parts guy cross referenced the part# I gave him with primelines and told me this is the one I needed. But maybe the placement of the 3 prongs is different than a cub brand? It plugged in fine. But since I'm taking the solenoid out to clean up paint I might as well pull the switch and double check it also.
Mine:
122 with 38" Deck, 123 with 48" Deck, 1650 with 44" Deck, #1 Tiller, QA42 Snowthrower
My Dad's:
Red 382 Hydro, Red 482 Gear
Old 04-27-2015, 12:57 PM
Since you bought a Non-Cub cadet part, just exactly what did you buy..???
Old 04-27-2015, 01:17 PM
TigerCub's Avatar
It was a Prime Line brand 3 prong ignition switch.
Mine:
My Dad's:
Old 04-27-2015, 02:00 PM
Well, I spent the time and looked in a Primeline catalog and could not find any switch matching your description. So, again, what did you buy...???
Old 04-27-2015, 02:09 PM
TigerCub's Avatar
I won't be home till tomorrow night, but I was told it was the OE replacement for IH-60736-C3 ignition switch. I didn't look in his book myself, I took his word that he knew what he was doing and found me the right part.
Mine:
My Dad's:
Old 04-27-2015, 03:14 PM
Let us know....
Old 04-27-2015, 03:31 PM
TigerCub's Avatar
I typed in the part# on eBay and this popped up that fits my model supposedly, I noticed the terminals are labeled differently than what the diagram reads. http:// http://m.ebay.com/itm/191437724044?nav=SEARCH
Mine:
My Dad's:
Old 04-27-2015, 03:33 PM
TigerCub's Avatar
Mine:
My Dad's:
Old 04-27-2015, 04:05 PM
TigerCub's Avatar
These are both diagrams for the 122, which is the right placement for the terminals on the ignition switch? Because if the top picture is wrong then the pins are in the wrong position on the plug.
Mine:
My Dad's:
