Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 05-10-2015, 04:21 PM
That linkage doesn't look right. What model tractor is this?
There should be something taking up the size difference in the hole on the governor arm and the linkage and the same at the carb.......
Old 05-10-2015, 04:39 PM
ssechrist ssechrist is offline
It's a 1987 2072, the engine is a Linamar, the carb is a Nikki
Old 05-10-2015, 05:51 PM
I'm not sure what happened but the linkage is working right now. I checked the intake & it is not leaking. I still have the problem of having to run the choke almost closed for it to run right. The carb has no adjustments on it other than idle speed.
