Old 05-17-2015, 10:06 PM
rdehli rdehli is offline
Jeff
I just wanted to know if the old clutch was assembled correct
spring pin...washer...teaser spring...throw out bearing ... washer...spring...washer...is the bearing facing the correct way?
Old 05-17-2015, 10:30 PM
There is supposed to be no washer in front of the teaser spring.
Up to 534 and counting...
Old 05-17-2015, 10:44 PM
Thanks. Is the throw out bearing facing the right direction?
Old 05-17-2015, 10:46 PM
Yes it is.
Old 05-18-2015, 08:25 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by rdehli View Post
with the motor moved forward the clutch cannot be turned, even with the clutch engaged and tractor in neutral the drive shaft cannot be turned , need some advice thnx in advance
also on the rear pressure plate is wanting to rub excessively on the the clutch engagement arm??? why? adjusting nut is all the way loose too.
This ain't right!
Old 05-18-2015, 08:35 AM
Carolina Cubber's Avatar
Carolina Cubber Carolina Cubber is offline
This ain't right!
Old 05-18-2015, 08:56 AM
In the pic the motor was pulled forward and the clutch disk had fallen down, it was not in the correct place when the pic was taken, my mistake. sorry
Old 05-18-2015, 10:45 AM
ironman's Avatar
My bad. Sorry.
Old 05-18-2015, 11:07 AM
Calvins66Cub's Avatar
If the roll pin at the transmission is sheared, could it cause this condition?
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 10-28-2015, 08:02 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Rob,
Did you ever figure out what the issue was? Was it because of the washer by the spiral pin that wasn't suppose to be in there?
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
