Old 06-22-2015, 05:46 PM
IHinIN IHinIN is offline
The axle tubes hold quite a bit of oil that doesn't get drained with the rest of the oil, therefore I added the drain holes.
The later Cubs did use needle bearings and all the info I can find says that they used the same axles so they must be hard enough. They constantly run in oil at low speeds so I think they'll be ok. If I knew what kind of steel the axles are made of, I would flame harden the area where the bearing rides.
I got one of the axle tubes bored out today and ordered new axle seals.
Picked up my engine rebuild kit today so I can now get the cylinder bored.
Old 06-22-2015, 06:54 PM
Nice work, I always do the drain holes on the aluminum rears when I have them apart.
Old 06-22-2015, 10:19 PM
Finished tearing down the engine today. The rod journal on the crank is only out of spec by .0005" so I plan on just polishing it and stay with a standard rod.
.0005" is the max out of round. I'd grind that crank. If not, you'll wish you did in a few years. Not likely right away..... but in a few years.
Looking good Adam!!
Old 06-22-2015, 11:34 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Looking good... I hold a special place in my heart for a 100... Learned to drive Dads when I was 4 years old circa 1975. wish we still had it! Keep the pictures coming!
Jay
Proud owner of the following:
Old 06-24-2015, 05:57 PM
Checked the cylinder head and found it was warped .010" so I milled .030" off to flatten it and bump up the compression a little.
Old 06-26-2015, 10:18 PM
Got the engine tins stripped.
Pressed in the axle bearings and new seals. Found a Stens seal that fits perfect. Has the spring on the back side just like the factory seals.
Had some gasket material so I made axle tube and rear cover gaskets. Need more material so I can make a shifter gasket.
Got a chuckle when I opened the box of the new piston and found this.
Old 06-26-2015, 11:45 PM
Terry C's Avatar
Terry C Terry C is offline
Bill's Motor World?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-27-2015, 11:50 AM
Adam you're coming right a long. I like your work as usual. Question, are you sure those ridges will clean out with just a .010" over job and piston?
Old 06-27-2015, 12:28 PM
The bore checks .003 over at the biggest spot. It will be fine.
Old 07-03-2015, 09:13 PM
Started putting the rearend back together. Scraped some loose paint.
Stripped some paint off of the tower.
