#21
When you get a second see if you can get the serial number for that critter. Looks like they may have used a couple different trannys in them. Here's a link to a PDF from Husky showing the trans, not sure if it's the correct one for your mower. http://www.husqvarna.com/ddoc/husi/h..._i0002002_.pdf PS: I think Justin may be right on this one.
#22
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#23
Nuts on Justin, the link you gave me was right on, thanks.
![]() Found that the one check valve that sits inside of the oil filter had backed out and fallen out of its hole.
#24
Glad to hear that you got it fixed and that Justin helped.
#25
Now you need to get that thing traded off on another Cub Cadet before it craps out on you again.
#26
I didn't kno any of those had any kind of hydro filter or screen.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
#27
Man am I good or what? Looks like I'll have to start looking into working on trans as well as engines
#28
![]() Glad you got it fixed Todd
#29
#30
Okay Justin, pat your back, you did good.
![]() Anyway there is a screen filter on the top inside the fill hole. I loaded the tractor and took it to my buddy's shop to help me with it... he actually took the until out and got it on the table to work on it. Found the trouble right off. So again thanks for all the ideas along the line
