Old 08-01-2015, 05:04 PM
bocephus1991's Avatar
Glad you got it figured out! I was thinking it sounded like a timing issue.
Brian
Old 08-01-2015, 06:12 PM
twoton twoton is offline
Default posting pictures
http://www.onlycubcadets.net/forum/s...13&postcount=1
I use method "B"
Old 08-02-2015, 01:44 PM
R.Parker's Avatar
R.Parker R.Parker is offline
i keep getting a "cannot display page" error on here when I try to upload a pic. Even when I try both ways
Old 08-02-2015, 03:02 PM
R.Parker's Avatar
Finally. ..
1806 cub cadet
1450 cub cadet
Sunstar 20
Old 08-02-2015, 03:04 PM
R.Parker's Avatar
My all original with 840 hours
1806 cub cadet
1450 cub cadet
Sunstar 20
Old 08-02-2015, 03:55 PM
timbo2's Avatar
timbo2 timbo2 is offline
nice score for $275. ag tires, paint and decals in nice shape too.
- Tim
Old 08-02-2015, 04:41 PM
Originally Posted by IACubCadet View Post
As far as your "idling down by itself" issue, have you checked the throttle cable where it connects to the engine linkage to be sure that the cable did not come loose from the clamp? If that is tight, then the only thing I can think of is that your throttle handle in the dash is loose. There is a screw that holds the handle to the mounting bracket, and if the friction washer comes loose they will idle down themselves. BTDT many times. Just something to check.
I was thinking that too......
Originally Posted by R.Parker View Post
I am happy to report that it was the timing. Point was set at .30 brought them to .20. Runs pretty good. Had to set governor up a tad but it runs well.
How would a guy adjust timing
Changing the point gap is how you adjust timing..... but not by guessing. If you set it with a feeler gauge, you didn't read the manual.
Here is how you set timing:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
If you don't do it correctly, it can cause damage.
You said the governor was closing the carb. You sure about that? When the governor moves in a quick motion as an engine starts to die, it is supposed to OPEN the throttle plate, not close it. If it was closing it.... something is painfully wrong. I'm not convinced you got your issue fixed.
Old 08-02-2015, 07:37 PM
R.Parker's Avatar
Well I did as manual says to do so...that was called static timing.
As I stated prior I bought this tractor this way. I was only tracking down the miss and the fact it would rev up and then idle down buy itself with throttle lever wide open. After I set the point cap it came right out of the miss. Mowed with it for 2 hours today didn't miss a beat. Sounds like it's fixed to me....
1806 cub cadet
1450 cub cadet
Sunstar 20
Old 08-02-2015, 08:27 PM
Yes, Mr. Parker, I understand. The book does say that the gap should be .020". However, many, many people do not read the information that is in step 4, which states that the points should break with the "S" in the window. On this old of an engine, you need to time it statically with the link I provided. .020" gets you close... but not exact. Many times you end up at around .015" when timed properly.
Do as you wish. I'm only providing assistance which is what you asked for.
Old 08-02-2015, 08:44 PM
R.Parker's Avatar
Thanks! The 1806 I bought for 140 bucks...needed a coil. It too had a miss...lol
1806 cub cadet
1450 cub cadet
Sunstar 20
