Old 08-16-2015, 09:58 PM
johns cubs's Avatar
johns cubs johns cubs is offline
John
What happens when you run any engine out of time? You get less power, poor fuel economy, depending on whether it was advanced or retarded it may run hot, and damage to the engine will result over time. These engine are no different than any other.[/QUOTE]
Thanks i knew that, I guess i wasnt real clear with wording. Just wondering why I would not notice a differance in how she ran other than starts a little easier. I guess prob because i have never had engine under a heavy load, meaning never mowed, or ran snow thrower. In fact i have never had to break half throttle while pushing dirt or pulling other tractors and/or trailers loaded around
John
Old 08-16-2015, 10:05 PM
That's why.
Old 08-16-2015, 10:51 PM
johns cubs's Avatar
Thanks!!
John
Old 08-17-2015, 12:06 PM
tpelle tpelle is offline
For the most part, you can pretty-much forget everything you know about points when it comes to the Kohler "K" series engines.
The only things that really make any difference are: The instant that the points stop making contact BANG the plug fires, and you want the "S" or "line" (which ever you have on your flywheel) in the middle of the window when this happens.
Since these engines are only firing 1800 times a minute and not 14400 times, duration doesn't really mean anything.
Simply put; It doesn't make any difference if the points open .020" or a foot and a half, as long as they get back closed again before 2 revolutions have elapsed, you are good.
It's all about WHEN the in the sequence of events the points break contact.
Ahhh. I see now. Makes sense when explained that way. Thanks.
