Old 08-26-2015, 01:58 PM
782CC 782CC is offline
That is tight. Glad my 82 series machines have more room. Having done all of mine now I would like to add. Be sure the bolt shank is long enough to support the pivot section. All of mine had excessive wear due to the support riding on threads of the bolt. To fix I found a bolt with enough shank length and cut off the excess to clear the mule.
Old 08-26-2015, 02:32 PM
The bolt length is 8", the shank is long enough that only an 1/8" on the axle is on threads.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-26-2015, 04:11 PM
4 machine I have done now all had 1/4 to 1/2 of the area with threads. I am guessing someone did not use the factory bolts in mine...
Old 08-26-2015, 05:28 PM
I just got a 122 with a very thin head bolt which looks similar to the O bolt. Anyone know what model they started putting in the pin with roll pin set up?
Old 08-26-2015, 05:42 PM
Does it have an oops pedal?
Up to 534 and counting...
Old 08-26-2015, 05:51 PM
You know I never even payed attention to that
Edit just looked no oops
Old 08-26-2015, 06:00 PM
I am working on a 122 today and the pin was a regular one,the othere one I was fixin has one also.po mod
Old 08-26-2015, 06:07 PM
You can make this easy or you can make it hard(er). The thick shim will fix the problem instantly and for very little money.
Old 08-26-2015, 09:52 PM
bkw3614 bkw3614 is offline
This is a great conversation!
When I did my 1250 Nightmare 4 years ago, I used the 3/4" bolt and nut to squeeze the C-channel together and re-set the axle with a new pin. I like the way the pin was machined with a depression cut into the middle of it to accommodate grease.
I like the modified bolt and nut idea, but will that take grease as well as the current style pin does? If I ever need to do this again, I will use the bolt and nut. It looks like a better option to me, if it will stay lubricated.
To everyone who contributes to this conversation, Thank you!
Brian Wittman
Old 08-26-2015, 11:11 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Is my thinking correct when greasing the front end. I jack it up on the frame. So the grease gets in the places that are normally under pressure from the weight.
