Old 11-16-2015, 09:53 PM
j4c11's Avatar
j4c11 j4c11 is offline
Talking How's your love life?
Tell us about your significant other, current or ex
Just recently I got tired of the batteries on my Black & Decker to never be charged when I needed to do yard work and decided to buy a gas trimmer. I went for a Husqvarna 128LD because I have had good luck with Husqvarna equipment. I usually do some research before buying something, but this time I didn't just because of the name. Big mistake, as I looked into attachment compatibility, I have learned that the 128LD is a rebranded Poulan Pro PP28LD. Pulled up engine diagrams and sure enough, same parts, same engine, so back to Lowe's it went, if I wanted a Poulan I would have gotten it at Walmart for $75 less. Went to Home Depot, dropped a little more cash and got an Echo PAS-225. Now I have some Husqvarna equipment and some Echo equipment, and mixing gas separately for each seems a bit crazy, but Echo demands that only Echo oil be used, and Husqvarna - you guessed it - that only Husqvarna oil be used.
- What is the general consensus on the use of non manufacturer-recommended oil in 2 cycle engines(e.g. Husqvarna oil in Echo equipment)? Is there one oil that can safely be used across brands?
- Some people are saying that a 32:1 mix ratio is better for your engine than the standard 50:1, and that 50:1 is more of an emissions/EPA thing. What mix ratio would you recommend?
- Has anyone had any experience with the AMSOIL 2 cycle oil? Some people are using that at 100:1 mix ratio .
- Some people are recommending drilling holes in the exhaust to reduce pressure caused by EPA mandated filters, and removing the spark arrestors. What do you all think, is that a good idea?
