Old 12-31-2015, 10:52 PM
PeterJ PeterJ is offline
I've looked at that before Ike and I like what you did. I've never seriously looked into it. I would consider changing out the dash too. I've seen the Command engine put into the older style tractor so it might be possible.
I'm always looking for affordable donor parts. Problem is no one around here ever advertises them for parts. They just scrap them. Not to mention the other problem. I do not have your talent for fabricating.
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 01-01-2016, 02:40 PM
Ikea6e Ikea6e is offline
Originally Posted by Rescue11 View Post
Ikea6e, i had seriously considered that as an option, but the dash is in too good of shape to cut up. Im also partial to the cyclops styling.
To date i have recieved most of my shipping confirmations. Hopefully this time next week it will look a little different. Provided Nightow1 doesn't decide to tear the rear end apart when we change the hydro filter...
I also like the Cyclops styling. I have good plastic for this tractor but, this project was just something I had to try. Thought there must be a way to use the 82 series sheet metal and retain the Cyclops tilt wheel, dash lights, etc.
I have an extra dash panel, plus I saved the wedges I cut out. Could glue them back in, it wouldn't be too noticeable. So it would be easy to go back to the Cyclops plastic.
Good luck with your project.
Ike
Old 01-01-2016, 02:46 PM
PeterJ
I put a CH 18 in a 782 awhile back. It was pretty easy and made a nice running tractor. As far as donor parts, I'm lucky to have some friends locally that play around with cubs and like to trade stuff.
Take Care,
Ike
Old 01-02-2016, 10:11 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Keith has been busy busy cleaning stuff up! With shipping confirmation on just about everything i have purchased, its time to get after things. We had our first encounter adding another valve to a cyclops series. Helps to have all the parts, but it was an overall simple experience. Have to get a few hoses made monday, go to a neighboring town to get the female cplrs and the hydraulic system is done.
1- 1200 in pieces
1- 1864 in pieces
Old 01-03-2016, 07:45 AM
Looking good.
Old 01-04-2016, 01:45 PM
1811woody's Avatar
[QUOTE=Rescue11;357549]Keith has been busy busy cleaning stuff up! With shipping confirmation on just about everything i have purchased, its time to get after things. We had our first encounter adding another valve to a cyclops series. Helps to have all the parts, but it was an overall simple experience. Have to get a few hoses made monday, go to a neighboring town to get the female cplrs and the hydraulic system is done.
Rescue11, I've wanted to add aux hydraulics to my 1863, I plan on using the parts from my 1862 parts tractor. When you added your dual hydraulics it got my attention . I though I saw a post a few years ago where someone was making a o ring coupler to go between the 2 valves for the supply? is that the route you went or did you tee your supply line? Any tips or pics on how you did yours would be appreciated
Old 01-04-2016, 02:37 PM
You can't "T" the supply line, they are open center valves. You have to feed it into one valve and out the other. Only way you can do it. Sam Mac had the short tubes made. I don't know if there are any left. They are NLA through CCC.
Old 01-04-2016, 02:56 PM
1811woody's Avatar
Ok thanks, I thought I remembered someone making some up. If Sam doesn't have any Rescue11 must have a source.
Old 01-04-2016, 04:20 PM
David Reinhardt David Reinhardt is offline
I contacted Sam a while back as to the availability of the ones he had made and he said he was out. I did some research ,some of the later cub cadets use the same setup for multi valve addition . The part number is 711 3294 and it's called a fitting union but some of the earlier parts list called it an adapter. They cost about $20.00 and are still listed as available. I have not purchased one but did check with the local cub cadet dealer and was told they are available.
Dave
Old 01-04-2016, 04:32 PM
1811woody's Avatar
Thank you for the info and part number Dave! Even if I don't add the valve right away it sounds like I should grab on of these adapters for future use.
