Old 12-12-2015, 12:46 PM
I got both quarters welded on last Saturday, I've spent the morning grinding welds and have now started laying the mud. For those who may be interested I use evercoat z grip bodyfiller.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-12-2015, 12:54 PM
sbauerz28's Avatar
Looking good. Have you every used Rage Ultra filler? What about SPI primers? I know the SPI satin black epoxy I got is UV stable and can be used by itself as a chassis paint. No need to top coat.
Old 12-12-2015, 01:52 PM
I have tried rage but don't really care for it and its about $20 a gallon more in my area.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-12-2015, 02:20 PM
I was getting ready to start sanding mud but as I was putting a fresh piece of paper on my board sander I lost my grip and it fell onto the cement, can't really sand anything with it now and I'm out about $150.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-12-2015, 02:58 PM
Is it broke?
if your board is bent, take it off and straighten it or get a new takeoff from ebay for $18.00 or so.
Them cheap harbor fright ones are ok, unless you are using it in a body shop situation.
Old 12-19-2015, 09:14 AM
Is it broke?
I just bought a new sander, my old one was on its 3rd board and was starting to get a little tired. Yesterday I move the car onto the lift so I can start cutting and patching the underside, the inner rockers need some repair as well as the trunk pan.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-19-2015, 04:41 PM
Sugarmaker's Avatar
Tim,
I had a 55 Crown Vic for about 30 years. At the time I did not have the tools or experience to do the body work justice. Your doing a great job.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 01-09-2016, 12:46 PM
Working on the crown vic today and wanted to share this pic, if you watched my video on bodywork you heard me talk about guide coat and this pic does a really good job of showing how well it works. This car was blasted and then coated with really thick epoxy primer, its so thick I can block sand it without sanding through. I guide coated the door before I started sanding and as you can see it showed me every imperfection.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-10-2016, 12:20 AM
Guide coat is king. Not that I have any experience with it but just seeing some friends using it, makes sense.
Now a question for the master body technician. Do you use seem sealer where you attached the patch panel on the quarter? Do you use a lap joint to attach the panel before welding? Just curios I suppose.
Old 01-10-2016, 12:46 AM
the patch panel had a step to it so it could slip behind the factory panel, once it was welded solid i just ground the weld down and started the bodywork.
Pap's 100
Restored 108
1211 Dual Stick
1050
