#21
I have a hydraulic cylinder repair shop near me, that makes hoses as well? Check your yellow pages.
#22
Jeff
In looking at the coupler that your making I don't see the bore that the ball bushing fits in like shown in the parts call out that the drive shaft centers in. #7 703-0794 Coupling Assy | (Includes Ref No. 8) #8 741-3004 BUSHING-BALL
#23
does anyone have a good pic of # 7 and #8 to post here, so that Jeff D can make me a new one. thanks in advance
#24
Rob
I would suggest that you measure the space between the coupler and the pump then remove your coupler and send it to Jeff so that he can build you a new & longer one.
#25
Rob, here are the specs on the ball bushing.
http://www.triangleoshkosh.com/produ...shings-he1410p I have a new coupler I can get some measurements if you or Jeff need those too.
#26
I'm going to toss out another option just to muddy the waters. You could also convert from the rag joint setup to a CV shaft. A 1541,1860,1861 or 1862 shaft and an adapter for the pump from Jeff should do it. I'd still make the adapter a little longer.
#27
Thank you very much Jeff |
#28
![]() ![]() ![]() It's "2-1/2 quarters longer" than factory with two set screws to negate the effects of the worn pump shaft. |
#29
Tempted to stay out of the conversation, if needed I could build you a nwe line. OR show you another route to go for a hydraulic line.
Just pm me
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#30
