#21
My biggest trouble was the torque tube was hitting the diff, so I needed to do some adjustment there... Then when you are tightening the drive belt try and keep it even on both sides. THE TWO BOLTS, that are used for belt tension.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#22
So that positioning bracket C straddles the axle pivot bolt...
#24
I would like to thank everyone who has helped me along with my Haban sickle bar mower so far. The help is very much appreciated. Thank You!!
#25
#26
According to my manual I need belt #5771 for 1974 and prior Cub. Does anyone know the width and length of this belt?
#28
Martin,
It is a 3V x33.5" this is for a 402-d but it will get you close to what you need.
Up to 534 and counting... I give up updating my profile! |
#29
I also see the manual says to flip the pulley so the hub is facing out for 1974 and prior so I will need to do that. Just 2 set screws from what I can tell. I find it strange also that the 402-E is for a wide frame but it has suggestions for as far back as mounting it on a 1964....they didn't have wide frame till 1971.
