Old 02-08-2016, 12:32 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Looking back at my pictures above, take a look at my home made wheel weights. They stick out about 5 or 6 inches. Will that interfere with plowing since my right wheels will be riding in the furrow?
Old 02-08-2016, 02:32 PM
That shouldn't be an issue, I saw tractors at PA plow days that had weights sticking out 12" or more. (Mostly john deeres )
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-09-2016, 08:42 AM
Jeff122's Avatar
Yea Tim. I saw some youtube videos like that. Noticed that only the JD's had those big fat weights. I just never got a good look at the furrow side. Turns out mine stick out only around 3 inches anyway. Always looking for ways to add more weight. Some say to load the tires.
Old 02-09-2016, 08:53 AM
I went to my first plow day last year and I was also concerned with weight, I had the rears on my 108 filled with washer fluid and my tractor did just fine and I had stop plenty of times because the JD in front of me kept getting stuck even though he had much more weight than me. The washer fluid added about 50lbs per tire so if your weights are close to that you should be fine but if you want a little extra you can add fluid and you should have no issues.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-09-2016, 09:01 AM
Jeff122's Avatar
My weights are close to 40 lbs each and I have another 50 lbs under the seat. Do you worry about your rims rusting with fluid in them? My first plow day will be this April only about 5 miles away. Doing some much needed maintenance on the 122 along with getting the plow set up.
Old 02-09-2016, 09:24 AM
Washer fluid won't eat the wheels like some other fluids will. Make sure you take spare parts, I was having an issue last year with the coil overheating which shut the tractor off, theres nothing worse then getting towed back to your truck.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-09-2016, 09:49 AM
Jeff122's Avatar
I see some coils for $30 on ebay. Not Kohler brand, but are they OK?
Old 02-09-2016, 10:48 AM
I couldn't say, if its 12v with an internal resister it should work but some coils are bigger around and won't fit in the cub bracket and the bracket that comes with it is to wide to bolt to the cub. My new coil we sell at work and it's the proper diameter and my 108 ran great all summer mowing.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-09-2016, 11:00 AM
Jeff122's Avatar
How much was that? Is it a brand I can find around here in NY? Or if you have other information and you'd rather PM me, please do so.
Old 02-09-2016, 11:03 AM
I will try to get that info for you and let you know later today.
Pap's 100
Restored 108
1211 Dual Stick
1050
