Old 03-01-2016, 08:39 PM
Mountain Heritage's Avatar
This is what the clutch looked like. I am going with the idea that the side of the field shouldn't be lifted up like that? Also those bits and pieces where it is breaking up don't look like they will be "healing" up anytime soon either?
Here is the result of your test Oak. Nothing. Couldn't get a read off it at all. Even shinned up the plate to make sure I was getting a good connection. Laying the probe on it or just using the point. Same result - nothing.
Sooooo....
I think I am going to get a different clutch from the dealer tomorrow???
Thoughts?
I was going to strip the one off the 782, but thought why would I do that and have TWO tractors to put back together?
Anyone want to have a beer with me tonight since I won't be moving snow?
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 03-01-2016, 08:57 PM
Looks like you got all the goodness out of that one. You'd think they would have built them to last longer than 40 years. You should see if it's covered under warranty.
Old 03-01-2016, 09:26 PM
Mike, make sure your meter goes to 0 if you touch the red & black leads of the meter together just to make sure your meter is working. If it does make sure that the wire that goes into the clutch isn't broken causing your reading. If all that is good then the clutch is now a paper weight.
Old 03-02-2016, 12:23 PM
Mike
Shrewcub is selling a clutch.
http://www.onlycubcadets.net/forum/s...228#post366228
Old 03-02-2016, 02:45 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The PTO clutch from a 782 (KT-17) and a 2072 (M-20) are the same ----> 917-3044
Actually, the 2072 is 917-3043. The field coil is the same but the rotor and armature are different. The 2072 and early 2082 had a 1.25" crankshaft. 17's and 18's had a 1.125" shaft. Late 2082's went to the 1.125" shaft.
Mike measure your shaft to be sure. I just checked a medium flat rate box to Canada is $46!
Send me a message with your address if your interested and I will check to see if I can do it cheaper.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
