Old 03-07-2016, 09:51 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
so how deep are those three holes we can not seem to see?
Some look like they had a bolt screwed into them, sawed off and then welded.
Old 03-07-2016, 09:58 PM
Originally Posted by Billy-O View Post
I rotated the original picture for those who can't see s**t........
Attachment 72877
That is much better Billy-O
It is plain as the face on your nose.
You guys still don't see it eh?
Old 03-07-2016, 10:01 PM
I see it now. Depth perception it what we are lacking. I was wrong. Once you guys see the depth of it you will see all his pics clearly. Still needs to be pulled off though as stated above, no way those are coming out.
Old 03-07-2016, 10:11 PM
OneBadBinder OneBadBinder is offline
That's what I was afraid of. I have a new bearing, kit and other parts on the way, I just want to make sure I can salvage the basket and pulley.. thanks for the help of making the mud clear and well... still mud I guess. :-)
-Wes
'67 125 48" Deck, 1A Tiller, 36" Snow Thrower, Push blade
'03 2166 42" Deck
Old 03-07-2016, 10:15 PM
These guys are old and have bad eyes,I see what you are talking about though,heheh,optical dillusion it is.
Looks like you have to remove the fingers on the clutch,pry them off,and the button and spring.Then use a 3 jaw puller and yank it off as one unit,BTDT easier if the motor is out
I have the hood/front end off of it so hopefully in the next day or two I can get my 3 jaw puller on there. Thanks
-Wes
'03 2166 42" Deck
Old 03-07-2016, 10:37 PM
Attachment 72877
That is so much better!
I knew in the first picture that, that was a valley and not a peak, but the shadow from the basket kept throwing me off.
Yeah, those ain't commin out the conventional way.
You could drill and tap them, but it would be a long slow process with it still on the engine.
Old 03-07-2016, 11:02 PM
budscub's Avatar
budscub budscub is offline
Default just a thought
It's really difficult to see exactly what you got there. I believe I would at least try to bust it loose before pulling with a puller. Could you place a 5/8, 3/4 or what ever nut that would fit over the mess, weld it hot, and try to twist off whatever the PO put on there. it may break em loose, might just twist right back off, and remove nothing. When I run into these type messes, I figure nothing from nothing leaves nothing, so why not?
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 03-07-2016, 11:28 PM
There is nothing to twist off, nothing is exposed out of the holes or even within a 1/4 inch of the pulley surface.
-Wes
'03 2166 42" Deck
Old 03-07-2016, 11:50 PM
Yeah I agree, there isn't anything down there to bite on, nuthin...
Yank it off and put it in a drill press and hope for the best Good luck, and let us know how it turned out.
Old 03-08-2016, 12:18 AM
Well I went at it tonight with the 3 jaw puller and a pry bar and off she finally came. You can see the set screws are still in there and the plate is pretty rough. Hoping I can get the set screws out and save the pulley. Didn't order new fingers on the first go round so gonna have to this time. Thanks for the help guys
-Wes
'03 2166 42" Deck
