Old 05-31-2016, 08:14 PM
Inactive Member
That is the Starter Solenoid. It was used to start the original KT-17 engine.
The 782 had some safety features built within the PTO Switch. If you put a simple on/off switch in place of it, you will be bypassing or eliminating these safety features. We can NOT advise you to do that.
Old 05-31-2016, 08:15 PM
chrismiele chrismiele is offline
Yes I have the original plate and a plate that came out of the 2084.
Originally Posted by RLause View Post
Here is a link to where the holes go.
http://www.onlycubcadets.net/forum/s...8&postcount=16
Old 05-31-2016, 08:18 PM
Agreed I don't want to eliminate the seat switch. Could I simply wire that inline with the PTO? Who's actually running a reverse safety?
Old 05-31-2016, 08:20 PM
Inactive Member
Another safety feature is, you can't start the engine with the PTO Switch in the "on" position.
Old 05-31-2016, 08:21 PM
I guess what I'm after is a complete rewire. I'm not against any safety feature, just want to wire it once and correctly. Trying to wire her anew, and blend in old components as well.
Old 05-31-2016, 08:25 PM
Inactive Member
Since you are making (or using) a non-specified engine for that model of tractor, a custom wiring diagram and harness will be needed.
Old 05-31-2016, 08:26 PM
Oh that's right i remember that feature. Ok. Well I feel like I've got the command wiring all laid out. I need to figure out how to get the reverse relay tied in. I have the 2284 diagram that was posted here, but it's got so many things that my motor and tractor don't that I can't get my head around it.
Old 05-31-2016, 08:27 PM
I'm sure that someone has put a command into one of these and preserved all safety features. Any ideas on who?
Old 05-31-2016, 08:32 PM
Inactive Member
There is another issue. The 782 had two different Wiring Diagrams. It depends on the Serial Number (age) range.
Old 05-31-2016, 08:36 PM
Mine is 720k and above. I have your schematic your drew in 2005
