Old 04-28-2016, 10:21 AM
Leadslingingdaddy's Avatar
Would that make the list as a "Homemade" Speed up Pulley?
Old 04-30-2016, 07:50 PM
twoton twoton is offline
So I've been following along on this and thought that it might be time to figure out what decks I have. I have 4 Quietlines that came with 3 decks. The decks are all the same except that one has a smaller center pulley. Up until now I always thought that the one with the smaller center pulley had been upgraded to a "speedup pulley". Now I'm not so sure. So following Rolands advice;
Measure the cut-width of the deck from LH Blade Tip to RH Blade tip, ie: 38, 44, or 50.
Therefor I have three model 44 decks.
The Center Drive Pulley will have to be changed to: IH-126393-C1.
I thought that IH-126393-C1 pulley was the speed up pulley as referenced elsewhere and in a thread by Maxwelhse;
http://www.onlycubcadets.net/forum/s...378#post195378
...which I thought was NLA??
Originally Posted by budscub View Post
I have a with a 44a deck, I believe it is original to the tractor.
The top of the center pulley measures 4-1/4" across the top.
You can see from the second picture that the center pulley (that I just removed) measures 5" across? I guess two of these decks could have originally been from model 1X8/9 tractors?
Randell....
Who's Randell?
Old 04-30-2016, 11:40 PM
There is NO such thing as a "speed up pulley" as far as Cub Cadet is concerned. The referenced pulley is a stock pulley used in an "non intended" application to give the blades more RPM's in that particular application.
The model 44 deck has a 5" pulley as stock.
The model 44A deck has a 4-1/4" pulley as stock.
Old 05-06-2016, 09:04 AM
riflemann riflemann is offline
Yes! On my 1976 1200 it has a 44 deck with a 5" pulley. I bought another 1200 yesterday, a 1978 and it has a 44C deck with the 4 1/4" pulley. I was amazed at how much better the 44C deck mows, but the blades are sharper also.
Old 05-06-2016, 09:31 AM
There were three (3) versions of the 44 inch Mower Deck
* 44 for the 1x8/9 Series
* 44A for the Quietline Series
* 44C for the 82 Series.
If you mix the decks up with the tractor series, you can come up with different performances.
Old 05-06-2016, 03:11 PM
Bedell....
Interesting!!!!
I think that the deck on my older 1200 is a 44, but the tag is very faded/worn.
It is no doubt a 5" drive pulley. So what are the differences between the 44 and the 44A?
thanks!
Old 05-06-2016, 03:16 PM
The center pulley....
44 has a 5" Pulley
44A has a 4-1/4" Pulley
Old 05-06-2016, 03:20 PM
that is all of the difference, the size of the pulley?
