Old 07-06-2016, 09:15 AM
Dane in PA Dane in PA is offline
Quick update shot of the 1812 with the new weight bracket.
Old 07-06-2016, 09:22 AM
Looking good!
Old 07-06-2016, 04:43 PM
yeeter yeeter is offline
Originally Posted by Dane in PA View Post
I put some Lucas Hydraulic Booster & Stop Leak in the trans, and its made a whole new beastie of it.
It sounds like this made a noticeable impact? In what way?
Old 07-06-2016, 06:34 PM
Very much so. I added (approx.) 8-10 oz of the Booster and Stop-Leak to the rear end. Hydro whine decreased in volume dramatically, hydro lift became more responsive, hydro became stronger and now takes less time to "spool up" when under load. It is also more responsive on the stick. 1/8" changes the speed respectively, and in real-time.
I will add it again, and use less than the recommended 10-20% of it in the system in this fall's fluid change --likely only 5% or so. I will likely put an additive in the engine oil, too. Running some SeaFoam in it now, in both the fuel and oil.
