Old 08-26-2016, 12:52 PM
Haven't made much progress lately, with everything that's been going on there just hasn't been time. I will be setup at the local fair all next week to promote the powder coat business so it looks like it's gonna be another week, I did put all the lines coming off the spool on hand tight and test fit the gas tank to make sure it clears and it does by about an 1/8". Next week is gonna be a long one, I will be working my normal hours at the shop and then I will be up at the fair for another 5hrs.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-18-2016, 04:59 PM
twoton twoton is offline
Originally Posted by twoton View Post
You fabricating the controls for the valve?
Any progress on this Tim?
Old 09-18-2016, 05:03 PM
Not to much, turns out I know somebody that's an amateur machinist and he made me these parts which will eventually become the levers for the valve.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-18-2016, 07:42 PM
Dirty Steve's Avatar
Looks awesome. Can't wait to see the rest.
Old 09-19-2016, 04:29 PM
That is awesome, Tim!
Old 09-19-2016, 06:22 PM
inspectorudy's Avatar
"Well its kinda like a virus, hydraulics that is... Hydraulic lift, then hydraulic outlets, and then you run a machine with power steering."
Yeah, it's called a John Deere 318!
1811 Hydro
Old 09-20-2016, 07:17 PM
Got some work done today on the handles, I decided to go with round stock for the handles which I will thread and put handles on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-20-2016, 07:59 PM
Coming along nice , If I may suggest, add circumferential gussets to the levers where they are welded.
Easier now then later when they break
Old 09-20-2016, 08:11 PM
I drilled into both pieces so the handles went in until they bottomed out on the cross shaft, I didn't just weld the rod on. I tested them out by putting them in a vice and I was pulling hard enough to start tipping the bench, should be plenty strong.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-20-2016, 08:20 PM
That should work well then.
I had not anticipated you drilled pockets.
