Old 02-03-2017, 12:29 PM
x.bhamcb x.bhamcb is offline
There are two sets of set screws, once you get the first set out there is another set underneath.
By all I meant 6. 3 flat point and 3 cone point. I probably should have specified.
Old 02-03-2017, 01:42 PM
Terry C's Avatar
Terry C Terry C is offline
Originally Posted by x.bhamcb View Post
I was under the impression that you had to remove the clutch from the bearing to be able to access the lock/set screw to remove the bearing.
Sorry I misread what you were asking.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-03-2017, 06:03 PM
The slide hammer worked to get the clutch off.
Is it normal to be able to turn over the engine by grabbing the outer race of the clutch bearing? Looks like I'll need a replacement.
Next step tear the clutch apart and see what else needs to be replaced, but first off to a movie with the wife (grandma is watching the kids).
Old 02-03-2017, 08:07 PM
No, it's not. Time to replace.
Congrats on a date night, we get them rarely, grandparents help out a lot in that department.
Old 02-04-2017, 02:01 PM
It looks like based on my assembly and the manual that the 149 should have two friction disks, but all the kits I see appear to only include one. Should it be two disks? Are there sources for two disk kits or the disk alone?
Old 02-04-2017, 04:49 PM
Are there any problems running the engine without the pro clutch installed? It doesn't seem like it would cause any problems.
Also, at what point should the friction disks be replaced? The clutch plates have worn into the surface of them about .020".
Old 02-12-2017, 05:47 PM
Is there anything special about the dowel pin (IH-19837-R1) that pins the driveshaft to the flange on the engine? Mine is broken and from what I can tell it appears to be a standard 1/4x1.5" dowel pin. Also, is there anything else I should check before replacing the pin.
Old 02-12-2017, 09:42 PM
Jeff in PA makes a gnurled one as if there's any wiggle room and the press is gone the pin will shoot out. That's the one I would get if you're not replacing the drive shaft. Also check the coupler for it being knotched out where the pin rides as most are
Old 02-20-2017, 05:12 PM
I should quit looking at this thing. Every time I look at it I find another problem.
Old 02-20-2017, 05:19 PM
I have never seen one of those break like that. No big deal to weld it.
Tags
149
